Question about Takamine G Series EG340SC Cutaway Dreadnought Acoustic Electric Guitar
Hi, I will buy a used Takamine EG340SC-NS but the gain button works backwards
Hi, I will buy a used Takamine EG340SC-NS but the problem is that when i went to tested i notice that the gain button works backwards. The min. level its the max. level, any body else have this problem? and the indicator light of "low battery" its on when i turned up the volumen level to the maximum, its this correct or a failure? This is crucial to buy the guitar because the seller tells me that its an origin failure and im not sure about that. The guitar its made in china and every time i more and more disappointed of this failures, please hel me! thanks . . .
    Master:
  • 923 Answers
What probably happened is that somebody changed (or replaced) a volume control (commonly called a pot, short for "potentiometer," but got the two outside terminals swapped, as to how the wires attached. No big deal ... just swap the wires (WITH NO POWER ON, and no connection to any power sources or other equipment)!
Posted on Apr 24, 2017
3 Suggested Answers
  • 5603 Answers
SOURCE: Hi i recently bought a
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
Posted on May 03, 2011
  • 5603 Answers
SOURCE: This is for the takamine
Most of the pedals are daisy chained right from the guitar. The output of the daisy chain goes into the DI box set to ground lift. An XLR to XLR cable goes from the DI box to the amp or mixer. Do NOT try to loop the sends and receives of the amp through PEDALS! The sends and receives are LINE LEVEL which is too high for pedals. The sends and receives are for external effects MODULES and EQ's that take line level. Some of those effect units have a foot switch to turn them on and off.
Posted on May 05, 2011
MY TAKAMINE IS CD132SC NYLONE STRING THE SERIAL NUMBER IS 99091756 CAN YOU TELL ME HOW MUCH IS WORTH AND WHAT YEAR WAS IT MADE?
Hi Michael:
I just Googled Takamine Acoustic guitars and got a bunch of hits.
My suggestion to you is that you do the same and try to find a guitar thatr is similar to yours and see what the asking price is.
I`ve played a tak and know that they have a good feel and sound.
Best of luck.
Oct 07, 2015 | Takamine Music
I want to know how much my 1962 Takamine is worth
Are you sure it's a 1962?
that is the year Takamine was established
Mar 21, 2015 | Takamine Music
Where to buy TP4T pickup
You can try repair it. They are pretty basic. I would look for poor solder connections, and reflowing all solder joints in it would be prudent.
The hum is likely from a gain stage with a bad solder joint on the input isolation capacitor. Also check other wires and check for bad solder connections on the pickup connections as well. It can even pick up hum through a bad shieid/ground connection in the jack on the guitar
Mar 29, 2012 | Takamine 1 NEW Takamine EG350SC G-Series...
I just purchased a Takamine acoustic/electric EG 350 SC which sounds great until I plugged it into a Mackey sound board. I sounded like distortion was coming out. In other words, it sounded like ****. I...
I ASSUME that you plugged your guitar into a DI box that then used BALANCED XLR cable to the Mackie board??? The guitar generates line level and the Mackie board inputs are mostly mic level... you will get distortion if you overdrive the Mackie board. You could try going into line level jacks, HOWEVER if you go any distance balanced interconnects must be used. Even the line level jacks require using TRS balanced cables. Try is using a DI box, and preferably one with a gain switch. Also fiddle with the ground lift switch on it for least noise or hum. I use the LiveWire brand DI boxes and they seem to work fine. Then it is important to set the gain with the trim on the MAckie so you don't clip. Also be aware that an acoustic guitar can "hear" speakers and you can get feedback or regeneration that will sound like you are in a cave.
Sep 05, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
I have played a Taylor 510 for about 20 years and I need to send back to Taylor for some need repairs. I know it will take 3-6 months to get it back and I am thinking about buying a Takamine ESN10c to use...
My son has a Takamine acoustic/electric. He plays in a band an is very accomplished. He and I both like the Takamine. He had a Fender acoustic/electric and sold it to keep the Tak. I have a hand made acoustic that I play at church. I like his Taka better. And I'm sure it's cheaper than another Taylor. The Tak. doesn't compare to the Taylor but it is a nice guitar and the electronics are good. One guy's opinion.
Thanks for using FixYa.
Gaker
Jul 29, 2011 | Takamine ESN10C Dreadnought Cutaway...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi! My TP-4T preamp on my Takamine EG124C works only when tuner is ON. After tuner automaticallt turnes off, the sound stops. Please help!
Hello,I am a guitar tech in Nanaimo,BC,Canada and have run into this problem before.Simply replace the Takamine output jack [where the guitar cord goes into] 3 screws and solder,and it will work fine again.The jack has a switching mechanism in it and when it fails it shorts the output out.The jack is available at most Takamine dealers or Allparts http://www.allparts.com/SearchResults.asp?searching=Y&sort=7&search=jack&show=20&page=5
Mar 06, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi! My TP-4T preamp works (sound present on AMP) while tuner ON only. After tuner automatic turn-off, sound stoped as well - some noice only. Can I repair such problem myself (I have an experience in...
Feb 03, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Takamine G Series EG340SC Cutaway Dreadnought Acoustic Electric Guitar Logo
50 people viewed this question
Top Takamine Music Experts
armandog07
armandog07
Ted Maxwell
richie46
Are you a Takamine Music Expert? Answer questions, earn points and help others
