Question about Cambridge Audio Azur 640T Receiver
My Cambridge Audio 640T (tuner) will not turn on, either through remote or panel. The standby light is on. What could be the problem? John
    Sergeant:
  • 256 Answers
That is not something that you can guess at,
Posted on Dec 06, 2012
3 Suggested Answers
cadillac02
  • 318 Answers
SOURCE: i have tuner AUDIO CAMBRIDGE
Azur 640T flagship or 640T (version2)?
What is you question and I'll see if I can help you?
Touch controls offering easy access to DAB and FM stations Receives traditional analogue transmissions and RDS Wolfson WM8716 24-bit/192kHz DAC Coaxial and digital outputs Natural Contour Technology (NCT) Low resonance, acoustically damped chassis improves sonic performance Stylish all-metal casework with a solid aluminium front panel Slim-line Azur remote control with aluminium top panel
Posted on Feb 06, 2011
SOURCE: NO SOUND FROM DIGITAL TUNER
Hi Guys, I have been doing some research on this problem and found that during manufacture of the Cambridge Audio DAB range that they had used substandard voltage regulators in these units. I have repaired a number of theses all with similar faults and every time replacing the 5v voltage regulators with LM340T5s and capacitor upgrade from 2200uf 16v to 4700uf 16v this will solve all the problems.
Posted on Apr 14, 2012
Thanks, this is answered.
Okay, thank you for the message.
Apr 17, 2012 | Cambridge Audio Azur 640T Receiver
Tip
Cambridge Audio DV30 DVD Remote Codes Download
Download Cambridge Audio DV30 DVD Player Remote Codes Manual
Would you like to review the features of the Cambridge Audio DV30 DVD Player?
Have you lost your Cambridge Audio DV30 DVD Player Remote Codes?
Would you like a digital, searchable, pdf version of the Cambridge Audio DV30 DVD Player Remote Codesl?
Follow this link (& click FREE) to download a pdf version of the Cambridge Audio DV30 DVD Player remote codes documentation.
I hope that helps.
___________________________________________________
Cambridge Audio DV30 Manual Download
on Jul 14, 2010 | Televison & Video
Tip
Cambridge Audio DV30 Remote Codes Download
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
I have tuner AUDIO CAMBRIDGE 640T NOT AMPLIFIER!!! PLEASE ASK GURU!!!!!!I
The question is - what can cause the problem seen on the photo below? CA Azur 640T - shows only the symbols after switching it on.
Feb 06, 2011 | Cambridge Audio Azur 640T Receiver
Tip
I hope that helps.
on Jul 14, 2010 | Cambridge Audio Sonata DV30 Player
Tip
Download Cambridge Audio DV30 DVD Player Manual
Have you lost your Cambridge Audio DV30 DVD Player Users Guide?
Would you like a digital, searchable, pdf version of the Cambridge Audio DV30 DVD Player Owners Manual?
Follow this link (& click FREE) to download a pdf version of the Cambridge Audio DV30 DVD Player documentation.
I hope that helps.
Dear mr I got a problem .i have a cambridge tuner 640T it plays only for 3 4 minutes all functions work and after that the screen is flashing and tuner stop working.(power stops).i got feeling that...
Excessive heat would be lack of sufficient cooling air. Give it room to breath.
Generally speaking, an amp protects itself from heat, shorts and overloads. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 01, 2011 | Cambridge Audio Azur 640T Receiver
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
Nov 28, 2009 | Cambridge Audio Azur 640T Receiver
Cambridge Audio Azur 640T Receiver Logo
310 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
