My Compaq Mini keep on asking me to enter a password at startup stage and I can't remembered my password. The setup is also asking the same. Please what do I do
  • 7,627 Answers
Do a system factory restore.
Posted on Dec 08, 2012
SOURCE: ERROR CODE
I have tried this, open the notebook from back and remove the CMOS battery and leave it for 12 hours, then boot the system and shutdown immediately and put CMOS battery on its place, then boot the system Junaid Pakistan
Posted on Feb 23, 2007
SOURCE: help
never say never, many factory functions available to those who can follow a simple pin out schematic
Posted on Nov 10, 2008
kamal1984
  • 1383 Answers
SOURCE: compaq c-series 2010c unlock utility code
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Posted on Jun 18, 2009
tanusha
  • 7 Answers
SOURCE: i have dell xps m1330 bios password
If u know the password put it if u dont know it just format u laptop I think that there isn`t any other solution....
Posted on Jul 01, 2009
  • 74 Answers
SOURCE: Can anyone help me on how to reset the Bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
Locked account
try this link:
Basically it's resetting windows password using a bootable linux usb memory stick. Use Ubuntu Linux To Reset Your Windows Password
Oct 04, 2017 | HP Compaq nc6400 Notebook
Compaq nc8230 stuck in startup loop after system restore to earlier date
on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter
Mar 13, 2012 | HP Compaq nc8230 Notebook
I have an advent netbook and when I turn it on all i get is 'bootmgr missing' ctrl,alt del to restart. If i press f11 im told to enter a password but i do not remember setting one. Is there any way...
You can try fixing the MBR if you have a spare windows disk handy.
  1. Put in the windows disk, then restart the computer
  2. If using a Windows XP disk, wait until the setup process starts and it asks if you want to install or enter recovery mode, press R to enter recovery mode. If you're using Windows 7, put in the CD, select your language and keyboard options, then select "Repair My Computer" on the bottom left.
  • XP: Press 1 then enter to select the windows installation. When it asks for the administrator password, type it if you know it. If you don't, it's probably blank, so just hit enter to go past this screen.
  • That will take you to a C: Prompt, at which you type fixmbr. That should solve your problem.
  • Windows 7: Select the OS (if none's listed, just select "next"), then click "Startup Repair". That should find/fix any startup problems. Try running it 3-4 times if it hasn't solved the problem, sometimes it takes multiple runs.
That should solve your problems, but if not the answer is to do a new installation, unfortunately. You can use the System Rescue CD to pull off any data that you need to save, then re-install the operating system and put your data back on.
Aug 18, 2011 | Advent Netbook
My HP mini 1000 is locked and I can't even get
Remove the cmos battery for 5 - 10 minutes. That will reset all data in the bios.
Jul 25, 2011 | HP Computers & Internet
Enter current password:? can't remember systems password for acer aspire one on linpus lite
http://wiki.e107.org/?title=Bypass_Windows_XP_Password there is an article about how to reset windows password. It must be helpful for those who have been locked out of computer
Jul 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Setup pasword
are you able to start the pc and boot dos for example?
if you can start the pc with a windows 98 startup disk for example
you can get the bios reset with debug program, if its not on the startup disk you need to get it online.
you can get a bootdisk here
http://www.bootdisk.com/bootdisk.htm
and the debug if not on the disk from your windows xp for eample.
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer.
If you can't start up.
here are some backdoor passwords to try
American Megatrends BIOS
AMI, A.M.I, AMI_SW, aammii, AMI!SW, AMI.KEY, ami.key, AMI~, AMIAMI, AMIDECOD, AMIPSWD, amipswd, AMISETUP, BIOSPASS
Award BIOS
?award, awkward, award, award_?, award.sw, award sw, AWARD_SW, AWARD SW, admin, alfarome, aLLy, aPAf, BIOS, biosstar, biostar, CONTACT, condo, CONDO, g6PJ, h6BB, HELGA-S, HLT, j09F, j64, j262, j256, j322, lkw peter, lkwpeter, LKWPETER, PASSWORD, SER, setup, SKY_FOX, SWITCHES_SW, Sxyz, SZYX, t0ch20x, t0ch88, TTPTHA, TzqF, wodj, zbaaaca, 1322222, 256256
Phoenix
phoenix
SystemSoft PnP BIOS
system
manufacturer preset ones
VOBIS & IBM: merlin
Dell: Dell
Biostar: Biostar
Compaq: Compaq
Enox: xo11nE
Epox: central
Freetech: Posterie
IWill: iwill
Jetway: spooml
Packard Bell: bell9
QDI: QDI
Siemens: SKY_FOX
TMC: BIGO
Toshiba: Toshiba
Jun 14, 2008 | HP Pavilion dv4000 Notebook
How reset bios password
go to ur bios set up and change ur password..
Oct 17, 2007 | Compaq Armada 1700 Notebook
Compaq 2500us hard drive
At some stage you may have activated the password in your setup especially the Administrator one. Can you get into the setup at the beginning....you might be able to disable it.
Sep 12, 2007 | Compaq Presario 2100U Notebook
Computers & Internet Logo
David Payne
David Payne
