Question about Cyber Acoustics CA-2016 Computer Speakers
Power Surge on Hub Port. A USB device has exceeded the power limits of its hub port
XP machine about 2 years old. after plugging in the speakers I get error message, "Power Surge on Hub Port. A USB device has exceeded the power limits of its hub port." this was after it crashed power on a WIN7 machine. Plugged into another computer monitor with USB, monitor turned off.
4 Suggested Answers
  • 619 Answers
SOURCE: Speaker has sound when powered .
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Posted on Jan 12, 2008
  • 70 Answers
SOURCE: Windows XP cannot find audio device - speakers
reinstall the drivers
Posted on Jun 07, 2010
  • 17 Answers
SOURCE: my speakers are plugged into
You must confirm that they are plugged into the correct output and also into a power source. If they are powered speakers it can either be the audio out or the headphone jack, if they are not powered then they have to be plugged into the headphone jack. Next confirm the audio driver is correctly installed. Finally confirm that the system sound and the sound for whichever program you are using is not muted.
Posted on Jul 14, 2011
I am getting error power surge on hub port in windows xp pro
your usb hub is exceeding the power limit or you are attaching a device that is extracting more more , use a USB 2.0 port HUB with a power adapter if you are attaching more devices on hub
Sep 24, 2009 | Computers & Internet
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
Use a powered hub, one that has it's own power supply.
May 09, 2009 | Microsoft Windows XP Home Edition
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Helpp! exceeded the power limits on its hub port?
a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
Dec 11, 2006 | Nikon Coolpix 5900 Digital Camera
Cyber Acoustics CA-2016 Computer Speakers Logo
46 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
