Question about JUMP START SYSTEM
Vec 1097 A battery charger always give cod F03 with any battery
Vec 1097 A smart battery charger 2/10/30 Amp and 80Amp for engine start always say Code F03 with any battery that I try to charge. I opened the unit but I din't find any burn component. If any body know how to fix this problem please let me know. Thanks
  • Jhonaleja Dec 07, 2012
    la entrada son 110 vts, inmediatamente saca el cod f03 y entonces para de trabajar solo me da 0.3 vots
    New Friend:
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Posted on Dec 27, 2013
2 Suggested Answers
  • 10865 Answers
SOURCE: need to buy the wall charger for my vector model
Call Vector and order what you need
Vector Products Customer Service # 1-800-618-5178
Posted on Feb 25, 2010
What is the error code f03 on the vector 1092 bettery charger
F03 - Sulfate or Unchargeable Battery
Appears when the battery is highly sulfated and cannot accept normal charge current.
• Follow the steps in "Recondition Mode" to recondition the battery.
• Follow the steps in "Equalizing" to equalize the battery.
• If the situation persists after reconditioning and equalizing, we recommend taking your battery to a certified automotive service center for evaluation
Aug 17, 2016 | Vector Camping, Backpacking & Hiking
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
The initial charge can require several hours, sometimes overnight. After that, recharges require less time. If your device doesn't turn on unless connected to the charger, the battery may be dead.
Apr 18, 2016 | Vector Camping, Backpacking & Hiking
How would I go about getting a charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
May 20, 2015 | Vehicle Parts & Accessories
How do i charge the battery on a 1992 honda shadow vlx 600c
First check the battery voltage using a multi-meter set to DC and volt range if reading is below 12V battery has probably one dead cell get a new one, if between 12v and 13V battery should be OK to charge. Remove battery undo negative lead first then positive. Please do not use a car charger or any other charging device that has an output greater that 1 Amp you will fry the battery. Charge the battery for as long as possible. Recheck volts across the battery if above 13V refit battery connect positive lead first then negative.
Start your engine, when warmed up check the voltage across the battery terminals it should be well above 13 volts. Increase the revs and watch the meter the voltage should increase to about 14.5 volts. This shows the battery is being charged. Please remember batteries on bikes only last a few years and short rides do not put enough charge in your battery. Buying and using a motorcycle Smart charger does help. I use a CTEK XS 0.8 12V Motorbike Battery Smart Charger & Conditioner. You get a small wiring harness that fits to the battery with a rubber connector that connects to the chargers plug. This unit will help to keep the charge in the battery topped up.
Jan 10, 2015 | Honda Motorcycles
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that...
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Jul 12, 2014 | Vector Black And Decker High Frequency...
I have a Lexus Rx400h, the engine won't start. the lights, including dashboard lights, aircon, radio are on, just won't go to ready and start
Can you ensure the car is in park?
Move lever to D and then back into Park and see what happens.
I have heard with this particular model, we have the environmentally unfriendly RX 330, that the batteries lack of charge may play havock with the electrics in these cars.
I religously charge my battery every six months with a smart charger so its always in peak, I also find a quick zap at the first cold snap of autumn / winter gives us trouble free motoring.
Apr 11, 2013 | 2007 Lexus RX 400h Hybrid
I have a Vector Smart Battery Charger 2/6/12 model VEC1088A-M. I am trying to charge a trolling motor battery but I get an error messager "F03." What does this mean?
F03 means 1 of 2 things:
INTERNAL OPEN CELL - Bad battery. Battery needs to be replaced or
SULFATED CONDITION - Battery needs to be reconditioned for 24 to 48 hours. See owner's manual.
May 27, 2011 | Computers & Internet
Im wondering if i can put a 80 amp 14v alternator for replacement on my 03 kia spectra 1.8l bottom base model which came stock with 80amp 12v can i up the voltage without hurting the car
Your alternator output normally should fall around 14 volts to deliver a charge to your car battery. Car batteries can easily adapt to 2V, 10V and 50V from a battery charger and likewise an upgrade from 12V to 14V output would not hurt anything.
Jul 27, 2010 | 2003 Kia Spectra
What does F03 mean
F03 is an error code with two possible meanings.
1) battery plates are sulfated, meaning they have a buildup of lead sulfate on the battery plates. Try charging the battery using the "Recondition" button on your charger. If this does not correct the problem then it may be option 2:
2) Open cell in battery. Have battery tested at an auto parts store and be ready to buy a new battery. An open cell means the battery is no longer usable.
Nov 18, 2009 | Vector Black And Decker High Frequency...
How do i charge the battery on my 2008 honda shadow areo 750
best way is to remove the seat and open the battery compartment then use a MOTORCYCLE charger (usually 1 amp or so) clamp the black cable to either an exposed engine mount or to the black wire on the battery clearly marked with a negative (-) then clamp the red to the positive terminal(+) then turn on your charger - if this is for long term storage a special trickle charger or smart charger for a lawn mower or motorcycle is best - never use a car charger they charge too fast and will create a heat buildup that will kill your battery prematurely.
Nov 18, 2009 | 1998 Honda VT 1100 C3 Shadow Aero
JUMP START SYSTEM Logo
506 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
