Question about Krups KB720 5 Speed Blender
Wont turn on - Krups KB720 5 Speed Blender
Why kitchenaid blender wont turn on ?
It's brand new, take it back. Messing around can only void your guarantee.
Jul 12, 2014 | KitchenAid KSB560 5 Speed Blender
How do i turn these things on
The switch may be jammed and/or defective. It probably will have to be replaced.
Jul 10, 2014 | Oster clipmaster variable speed, oster
Wont start
If it will not turn on when cold then you are likely looking at a new motor. If there is a resettable fuse reset it.
Jan 25, 2014 | KitchenAid Professional 600 6 Qt. Stand...
Wont turn on,just blinking light
This will probably need either a new thermal fuse on the field windings or a new motor.
Nov 17, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Avanti pasta wiz
The problem is with the Avanti Pasta Wiz's soft metal gears. They have bent and your machine is now likely usable. You should return it to the retailer and ask for a refund.
Jun 19, 2008 | Blenders
Krups KB720 5 Speed Blender Logo
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
