Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
    New Friend:
  • 169 Answers
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Posted on Dec 10, 2012
    4 Suggested Answers
    • 126 Answers
    SOURCE: i have a elkay double level water fountain and the
    is there power to the unit.could be selinoid problem
    Posted on Sep 25, 2011
    muralme
    • 20 Answers
    SOURCE: elkay water cooler does not turn on
    You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
    Posted on Jul 17, 2009
    • 127 Answers
    SOURCE: water pressure is low on the elkay fountain
    if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
    Posted on Oct 18, 2009
    Elkay vrc hd8 drinking fountain is leaking how do i fix it
    Replace the gaskets on th ep-trap and thre tray to drain gasket.
    Aug 18, 2014 | Elkay EZS8-L Single-Level Wall Mount Water...
    Elkay water fountain, model# erpb2_8c,how do I take apart to replace water spout?
    There are between two and four screws, probably 1/4' or 5/16' hex, on the underside of the cooler. Remove them. Make sure the water is shut. There should be a valve similar to those found under your bathroom or kitchen sink coming out of the wall where your cooler is mounted. Locate the plastic tubing that supplies water to the bubbler, (water spout), and press in the collet. The collet is a collar that slides back and releases the tubing. While pressing the collet, pull on the tubing. It should slide right out. Now you must remove the mounting nut, and viola! You can remove the bubbler.
    Jul 18, 2014 | Home
    This fountain is located at my church, the problem: The water dispenses, then it doesn't. Wait a while and it dispences again, then it doesn't. It did not do this before now it does...
    sounds like there is a build up of minerals in the water line that is coiled around the cooler unplug from wall take off cover and run fine wire through copper tubing
    Aug 02, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
    I have power and water to the fountain, but fail to get the water to pump to the fountain head
    The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
    Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
    How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
    On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Water pressure is low on the elkay fountain
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Water won't stop running
    very simple,
    button behind pushbar either bad, or real dirty. clean or replace.
    Aug 29, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Elkay water cooler does not turn on
    May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
    167 people viewed this question
    Top Elkay Plumbing Experts
    jdthefixer
    Steve Wood Plumbing...
    Level 1 Expert
    robert
    Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
