Question about Audiovox AXDVD1 Slot Load Single Disc DVD Player
Connection wiring into monitor
Monitor says no connection then goes to sleep
Mine did that not long ago and it was so annoying. I suggest that you check that you make sure all the wires are connected to the back of the monitor so you could push them in a little to make sure. You can also check the wires at the back of the computer.
Another solution which is what I did was I unscrewed the side of my computer and wiggled the graphics card. For me, this was the panel closest to the main wire that connects the monitor to the computer. After this, my monitor worked again.
This may not work for you but hopefully it does.
Jan 30, 2013 | HP 2009M Monitor
How to connect dual monitors to docking station
one monitor you have onto laptop, second monitor connect to laptop connector for external monitor and in menu Start - Settings - Setting panels - "Icon - Viewing" and for this dialog window select folder "Settings" and configure secondary monitor
Apr 21, 2012 | IBM ThinkPad T40p 2373 Notebook
The monitor screen flashes on and off. It gets worse after being on for a while. A box pops up saying no signal.
Usually due to a faulty connection between the computer and the monitor.
  • Remove the wire that connects the computer to the monitor
  • Look at the pins on both ends.
  • If there's any bent, change the wire.
Sep 16, 2011 | HP w1907 LCD Monitor
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Benq g2400w lcd monitor how to get sound working on the monitor only connected thru DVI
If this montor has built in speakers you would also need to connect the audio wire to the computer. It should be a wire with a green jack on both ends, You'll connect it to the audio in jack on the monitor and the green jack on the back of your computer. Hope this helps.
Oct 09, 2009 | BenQ G2400W LCD Monitor
How to connect build-in monitor speakers? should i just connect regular audio cord to "audio out" of comp to "audio in" of monitor? (if so, -it dosn't work). Help please
does the jack on lcd monitor, is it a screw type one, open or take aprt the screen area look at the speaker wires and take aprt the wire to you speaker if each have 2 wires you will be able if you have 3 or more wire you be able to talk to a tv repair man and see if he will make that connection for you permitily hard wire the two systems.
rod
Feb 18, 2009 | Jetway M1531S 15" Flat Panel LCD Monitor
Wiring problem
the monitors are made by power acoustik there is a green wire a red wire and the white wire has a wire in the middle surrounded by ground wire8a804da.jpgd2d189c.jpg
Sep 16, 2008 | Power Acoustik 7 Widescreen Headrest...
Problem with Samsung 17" Syncmaster 793 MG monitor
You might be having problems with the cable connection from the monitor to the video card. Check the cable for open wire.
May 05, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
White lines going across the screen
THere are two possibilities
1. problem in mother board
2. problem in monitor
To make sure if possible connect your CPU to another monitor and see if all is fine. If the other monitor works fine, then your monitor has th problem
if the other monitor also has lines, then the mother board's video card has prob.
Also check the connection wire between the CPU and monitor that there is no loose contact or any cuts or damages in the wire
Apr 11, 2008 | Computers & Internet
Audiovox AXDVD1 Slot Load Single Disc DVD Player Logo
24 people viewed this question
Top Audiovox Computers & Internet Experts
Greg Cann
Greg Cann
Martin Murray
Arora Singh
Arora Singh
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
