Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
My Whirlpool gas range will not cycle out of the cleaning program. this is a older stove and it is free standing. I can not find the model and serial number anywhere on the range and of course I can
I cleaned the oven last night. I let it clean and cool over night. When I tried to reset the oven to bake the oven will not turn on.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Did you look inside the oven area and the lower storage (if it has it) for the model number?
Posted on Dec 06, 2012
SOURCE: locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Posted on Nov 04, 2006
  • 1894 Answers
SOURCE: Whirlpool Gold Accubake self-cleaning gas oven door lock solenoid
i think there is some kind of shorting somewhere.
Posted on Jun 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
SOURCE: Whirlpool Range Model GR399LXG
Accidently hit the autoclean and then stopped it, Now the oven will not lock so I can't clean my oven
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Super capacity 465 Whirlpool range . E1 F5 code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
Posted on Oct 01, 2010
Whrilpool gas range Mod. GW395LEGD0 Serial IMJ0663181 OVEN DOOR LOCKED CAN NOT OPEN
If its a self cleaning model and you tried to stop it in the middle of the cleaning cycle the door will not unlock. Disconnect it from the power, let it stand a few hours then plug in. If not opening try running the self cleaning mode and let it finish completely. When it finishes after it cools down sufficiently the door lock should go off.
Aug 09, 2014 | Whirlpool GS460 Gas Kitchen Range
No spark when pressing piezo on free standing gas stove lake field model from cozy heat
https://www.youtube.com/watch?v=PicYiwm-VSk
This you tube clip may help ....
Your issue may indeed be a broken piezo ... or as the clip indicates ... cleaning the tip of the piezo could help or there may be a broken/loose wire somewhere in the circuit.
Good luck on your troubleshooting!
Jan 09, 2018 | Kitchen Ranges
Premier free-standing gas range, 20", how much clearance from wall?
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Feb 05, 2013 | Premier Kitchen Ranges
Gas range thermastat
Manufacturer Number W10159016
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-5-655221-/Whirlpool-Oven-self-cleaning-problem-SF3020EKQ3
Nov 05, 2012 | Whirlpool GS460 Gas Kitchen Range
Can not work automatic clean cycle on Maytag range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 05, 2010 | Maytag MER5775Q Electric Kitchen Range
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool gas range spark ignition problem.
check the burn head, there is a tube from the ignitor to the burner head. that is where the gas get ignition. now look at the burner head, there should have 2 small pin hole align with the tube. use a paper clip clean out the hole.
May 21, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Pilot lights
Good news. All gas providers, the company you get your gas from and pay your bill to have a free servce where they send out a technician to light your pilot lights for you. Just give them a call.
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
88 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
