Question about Kitchen Ranges
Duel fuel Bosch 2006 range with error 122 on readout board. What to do? Just had both boards replaced.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 06, 2012
Illeagle
  • 525 Answers
SOURCE: I require a replacement manual for my De Dietrich CX4744U1 duel fuel range cooker.
Here are some links that I have found to be helpful. Good Luck!
http://www.retrevo.com/samples/Microwave-manuals.html?cmpid=Manuals_Microwave&gclid=CPO8ouufvZMCFRUWsgodIg3EDA
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
frankgant
  • 250 Answers
SOURCE: F6 Error
I contacted Dacor and they stated that the F6 error means the ERC or Electronic Relay Control is bad. This part would need to be relaced. They gave me a parts company to contact for the part. It is Appliance Parts Depot at 1-800-642-6420.
Posted on Jul 09, 2008
Krazytech
  • 725 Answers
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
  • 3 Answers
SOURCE: Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Posted on Jan 02, 2009
WRMtech
  • 70 Answers
SOURCE: The display panel for the oven control of our
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Posted on Feb 26, 2009
I have Bosch self cleaning oven, door will nit open and control panel says error 43 what do I do?
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
Error 43 on Bosch range how can open the oven door
Mar 26, 2018 | Bosch Ovens
Apr 30, 2010 | Kitchen Ranges
I have an error code 45
As per Bosch,
Error Code: F45 Cause: Upper (or single) oven latch both locked and unlocked; Defective or jammed upper oven door or latch switches. Corrective Action: 1. Check P4 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are pinched to the appliance chassis. 4. If F45 persists, replace power board
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
How to cancel f9 code
JennAir F code 9
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Nov 10, 2009 | Kitchen Ranges
BOSCH RANGE HGS3052UC ERROR 160 AFTER REPLACING PANEL
f160 is cooling fan error
board not reading hall sensor on cooling fan
could be cooling fan not turning
hall sensor on end of motor not plugged in or hall sensor broken
Nov 24, 2017 | Bosch HES 232 / HES 236 Electric Kitchen...
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or...
Feb 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
220 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
