Question about InFocus Office Equipment & Supplies
My projector is shuts down automatecally - InFocus Office Equipment & Supplies
    Champion:
  • InFocus Expert
  • 225 Answers
Does it come on at all? If so you may need to clean the filter.
Posted on Dec 06, 2012
The projector lamps always burning out. I think, the cooling system does not work?How does the projector work?
Make sure not to shut down the projector after use. Wait until the fan stops. The fan is to cool down the bulb during and after use. Once the fan stops, then you can shut it down.
Feb 29, 2016 | Office Equipment & Supplies
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
The projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Projector stays on for a while then shuts down
Two things that usually gives this symptom. One, internal heat sensor will shut down projector if extreme heat is present, usually caused by dirty filters, fan failure, etc. Two, your bulb has reached its life end.
Feb 02, 2009 | Eiki LC-XG210 Projector Multimedia...
Turn On Problem
Are you sure you are actually shutting down and not entering sleep mode? Sleep mode does use power while it appears to be off, it resumes instead of powering on. Have you tried removing the battery when charged and allowing it to sit over night or a full day then check the charge level. If the battery discharges regardless of being inserted, then the battery is at fault.
Nov 05, 2008 | Acer Aspire 5580 Notebook
Benq mp610
I replaced my lamp on my Projector MP510 after the projector shut down. I followed the instructions in the book to reset the projector but the projector shuts down all the time. Please can you help me HARRY
Sep 14, 2008 | BenQ MP610 Multimedia Projector
Projector indicates overheating and shut down
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Apr 21, 2008 | Eiki LC-X50M Projector
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
