Question about Life Fitness Exercise & Fitness
Showing e3 showing error 3
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
This indicatin is problem with the speed sensor, see the diagram attached, test the s. sensor for open or faulty. clean it, and tigh the plug or connector very well.
Try to run The software calibration for easy diagnose,troubleshooting, and fix it.
God bless you
Posted on Dec 07, 2012
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
Dishwasher showing e3 error
E3 error arises due to the malfunction of temp sensor or the heating element. Check for the thermostat.
Jul 02, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
My unit trips off and shows E3 on the screen
E-3. INDOOR FAN MECHANISM LOCKED/ No power to F.Motor. Check motor by rotating manually. If hard, replace motor. Or PCB defective.
Jan 12, 2011 | Carrier Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
PANASONIC KX-TG2258 E3 ERROR CODE
This method worked for me!! you guys should try this.
i've copy this review from amazon.
by Kane Doerfler
"After a brief power outage from a thunder storm, I also experienced an e3/lights blinking error. I unplugged the phone and plugged it back in several times to no avail. After doing this a couple of times unsuccessfully, I hit the "STOP" button on the base immediately after plugging it in (before it completed booting up to show the "e3 message")and it reset itself and now works fine (or as well as it did prior to the e3). Try it before tossing yours in the garbage"
thanks to Kane. I saved my phone~!!
Nov 17, 2007 | Panasonic KX TG2258S Cordless Phone
Exercise & Fitness Logo
265 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
