Question about GE Televison & Video
GE gemstar tv the outter sides of the tv are moved
Today i turned the tv on and it was fine then all of a sudden the tv screen went all screwy. It looks like everything but the middle of the screen is shifty. You cant see the channel numbers or half of the outer edges of the channel are missing like the screen is magnified.Could a Bulb be going out? or is my tv fried
    Top Expert:
  • GE Master
  • 14,553 Answers
If it is so badly curved the channel display is hard to see you have a part in the set bad---these like most have a pincussion circuit--it is individual parts that make the set have a straight picture on the sides especially, years (decades) there were controls in sets for this but to make sets cost less they use fixed parts.
It will not be an expensive part in most cases but finding it and replacing it in a older set may not be economical.
If you really like the set call a few shops to see if they will work on it and get a ballpark estimate.
Let me know if you have questions.
Posted on Dec 06, 2012
  • 18 Answers
SOURCE: Tv has lost two outer sides of vision despite changing picture mode
That's either a high voltage problem, or a deflection problem. WARNING, CRT Based Televisions have potently life threatening voltages inside them, and should be serviced by trained personnel only. With that out of the way. According to http://www.repairhelper.com It's a capacitor failure Fault - Width and E/W correction fault Remedy - Replace R626 and C630 I don't have a manual so I can't tell you for sure what the resistor and capacitor do, or where they are located.
Posted on Jan 13, 2007
SOURCE: Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Posted on Mar 02, 2007
  • 556 Answers
SOURCE: can only see half the picture
your problem is in vertical output section.
the ckt which is connected to vertical output section is called feedback ckt.
please check.
1 loose contact in feed back ckt.
2 mostly this problem is due to electrolytic capacitor failure.
3 vertical output  IC or transistor failure.
4 check for proper supply to vertical output.
5  low value resistor failure in v/output ckt  (.in rare case)
IF YOU ARE NOT TECH PERSON PLEASE TAKE HELP.
  1. hope this will help.
Posted on Oct 10, 2007
SOURCE: GE 31GT740 TV problem
hit the clear button on the remote and it will clear the guide plus off the screen
Posted on Sep 28, 2008
ginko
  • 19396 Answers
SOURCE: Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Posted on Oct 03, 2008
Red convergance is un-adjustable
Yes you can get the repair kit for your model at www.tvrepairworld.com the kits contain the two ICs and the 6 resistors plus the CD with step by step instructions.
Jan 06, 2010 | Panasonic PT-56WX53 53" Rear Projection...
I have a PS3 slim that often have video problems. When I use the AV cables, it shows white line, and if HDMI, blank screen. The console does not turn off, no blinking lights. When I turn off the console,...
Does your tv run everything else fine? Sometimes cables r screwy or the tv is screwy(I'm not denying that you have a bad ps3) but you can still get the warranty on it. If the second one does it,it's not the PS3 its your tv or your cables.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Pretty colors
Sounds like the other DVD player went bonkers. Try unplugging power on the DVD player you were playing the game on for 5 minutes, then plug it back in.
Apr 02, 2008 | Sony DAV-FC8 System
Red Gun screwy!!
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sep 17, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
26 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
