Question about Canon PC-795 Copier
Canon pc795 feed roller problem
Feed roller
3 Suggested Answers
SOURCE: PC795 copier won't pick up and feed the paper into
The paper feed tire(s)
Posted on Mar 15, 2009
  • 92 Answers
SOURCE: Canon Copier PC795 shuts off while copying. is
no there are no power supply,its NO LONGER available.you have some new ones like imagerunner 1020.
Posted on Oct 23, 2009
03130031-2f2a error
The feed roller home position sensor is not detecting the feed roller position, obviously, I would say.
Or the circuitry that senses what that sensor is telling it, isn't connected or is just plain dead.
Determining what exactly the problem is depends upon an examination of the machine, in the area of the feed roller. In this sort of Canon printer the feed roller is the roller that starts feeding blank paper into the machine - and that is, needless to say, a large roller near the back of the paper stack or just over it. That's where you have to look for something wrong.
IF there's a spindle or shaft there, with no roller on it, then there's your problem: no roller to sense the home position of.
Feb 13, 2018 | Canon Office Equipment & Supplies
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Feb 07, 2018 | Canon PIXMA Office Equipment & Supplies
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
http://www.precisionroller.com/paper-feed-components-for-canon-laser-class-2050p/products.html
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Canon D480 document feeder doesn't always feed documents
First, try changing some Document Feed Rollers etc.
FC8-9251-000 is the pickup roller
FL3-1023-000 is the separation pad
FM3-8679-000 is the feed roller
That would fix 80% of the problems you may encounter
Whit
Item, Inc.
Sep 28, 2010 | Canon imageCLASS D480 Black and White...
Oct 23, 2009 | Canon PC-795 Copier
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
Does anyone know the difference between a canon ****** roller and an exchanger roller on a canon dr-2080c scanner? I am looking to replace the rollers that are ageing and now "picking" up more than one...
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Canon PC-795 Copier Logo
70 people viewed this question
old marine
old marine
