Question about Creda C362E Electric Kitchen Range
Cold air is coming out of the main oven - Creda C362E Electric Kitchen Range
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
I have just purchased a Neff U17M423GB built under double oven from JL. When I put it on preset timer for the bottom oven, the fan starts blowing cold air out of the vents above the top oven. When t
if this is gas it calls the induced draft motor to come on for 15 to 20 seconds to clear any residual gas before beginning the ignition process begins. Very normal and a safety feature.
Nov 20, 2014 | Neff Ovens
New Kenmore elite range blows cold air from oven vent when top burners are on. Is this normal
That sounds a bit unusual.... Does the fan come on when you turn on the oven on bake? How about on broil? How about on self-clean. If it comes on in all those settings, then it may be working as designed. If NOT, they there may be a crossed wire, or you may have a malfunctioning control.
Nov 11, 2014 | Kenmore Kitchen Ranges
When the oven is on cold air constanly comes out the vents over oven door. Never did that with ild oven. thanks
This is the oven cavity extractor fan. It removes all the hot air from the oven cavity and blows it out the front. When the oven is hot and you turn it off the fan will continue to work until the oven cavity cools down.
Feb 12, 2011 | GE Ovens
Fan oven blowing cold air
If it is the main oven blowing cold, then you need to replace the oven element.
This is located at the rear of the oven, behind a removeable cover.
This should solve the problem.
Dec 14, 2009 | Neff U1721 Double circotherm Electric Oven
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Cannon oven not working
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Jul 14, 2009 | Bosch HBL 5032 Electric Single Oven
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Creda C362E Electric Kitchen Range Logo
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
