Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a Whirlpool Cabrio topload HE Washer. The problem it is having is that it makes a banging/knocking sound when it is agitating.
The problem it is having is that it makes a banging/knocking sound when it is agitating. It started doing it when I had the setting on sheets and towels but not it is doing it more often. It does not seem to interfere with the working of the machine but it is loud enough that I think it might one day cause something to break. Any ideas?
    New Friend:
Dl code keeps flashing and buzzing on my whirlpool
Posted on Oct 01, 2013
  • 403 Answers
SOURCE: the load finished on my
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
Posted on May 05, 2011
  • 530 Answers
SOURCE: ON SPIN CYCLE AGITATOR MAKE A LOUD BANGING SOUND
So while you are holding the agetator is it ripping your hands? or is the agetator just sitting there? If the agetator is just sitting there you probably have bad agetator dogs. I would remove the fabric softner or cap whichever you have. under the cap you will see grooves in the agetator down low. When you manually turn the agetator you should see 4 tear drops that grab the grooves if you do not see this you have bad dogs. Very simple. This usually is the cause for the grinding noise that you are hearing. Please let me know if this works for you //eg
Posted on Jan 12, 2009
  • 125 Answers
SOURCE: Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Posted on Jan 09, 2008
  • 130 Answers
SOURCE: Slow spinning agitator with knocking sound
agitator dogs. take them out and replace.
Posted on Feb 28, 2009
cactus bob
  • 267 Answers
SOURCE: when whirlpool cabrio washer is spinning, it sounds like a chain
sorry no chain there ! sounds like a basket mount may have come unhooked or broken you should still be under warrinty i would call them the mounts can be a real pain and even if you did get it back together ,you may have parts made wrong makeing it out of balance .makeing the machenes lifespan shorter than it should be ......... ps : i dont want to alarm you but make sure you have an extened warrinty on this washer ! . this washer has one of the worst track record of any washer ever made , whrilpool keeps saying we have the bugs out of it now . but people like you keep haveing brakedowns .....so just cover yourself .............if you plan to rate this answer , please rate it a 3 or 4 stars , that will help keep me in the paid answer department . thanks
Posted on Apr 01, 2009
My whirlpool model no 6alsr72 washing machine makes a knocking sound on agitation
remove any clothing restart empty run cycle if still knocks its needs to be re leveled
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Feb 06, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Wtw6300sw1 agitator moves clockwise no counterclockise mov
    This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
    Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
    It sounds like my whirlpool cabrio topload washer has a coin in it rattling around but the tub is empty. What if anything do I need to do?
    Take the back off and run it take a flashlight and look inside for something that might have come loose.Hope this helps have a great Thanksgiving.
    Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool topload filss, will not agitate, spin or drain.
    This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
    When you purchase your parts through us, we provide part removal/installation instructions.
    You may contact us at:
    WWW.Accurate-Appliance-Service.com
    We look forward to working with you and hope this gets your washer in good working order again.
    Have a great evening, Ella
    Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Feb 28, 2009 | Whirlpool Washing Machines
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    562 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
