Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting a F 05 error message, what does this mean
I turn on my washing machine and after about 5 minutes I get a F 05 message.
Hi I'm having the same problem will it go away
Posted on May 06, 2012
The Fault is to do with the on board comp panel I had the same fault, you can either wait till it stops than put it into rinse and spin or take out a service plan for about £85.00 cos the part is very expemsive
Posted on Jan 12, 2009
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
Get error message F5 about 3 minutes into the cycle, have to reset multiple times to override
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
I have a service manual and some repair photos HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Not draining water, error message f-05
You need to check the pump assembly, and check to see if the pump is blocked.. Then unplug for 2 mins, and try again
Jan 12, 2010 | Indesit W 123 Front Load Washer
After about 5 minutes into a wash cycle, the error "E02" is displayed and the wash cycle stops. What does this error message mean? It isn't in the book that came with the washer.
I just had this problem. My water supply (hot ) had been turned off since my husband used it to fill our hot tub. Other causes were-supply hose kinked,strainers in supply hose clogged, water pressure too low. Hope this solves your problem!
Jan 09, 2010 | Bosch Nexxt 300 Series WFMC2201UC
What does error code E2 mean? I have a Bosch Maxx Classic.
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Nov 03, 2009 | Bosch Washing Machines
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
Jul 13, 2009 | Whirlpool Washing Machines
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal De
