Question about HP "View Sonic Pjd5353 1080P Front Projector, 300 Inches - Black"
My view sonic projector is displaying black spots.
Display shows black dots.
    Champion:
  • HP Expert
  • 225 Answers
Most Likely a bad DLP/DMD chip. If its under warranty they will fix you right up. Other wise you have to pull it apart get out the chip and then order another one for a few hundred bucks.
Posted on Dec 06, 2012
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
Small white spots on screen acer x1230k
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Nov 21, 2013 | Acer X1230K OEM Projector Lamp
I have lines and black spots all over display
Most likely you have a failing DLP chip. The DLP chip is the one that forms the image that is projected onto the screen. Search for "Mitsubishi Black Dot" in your search engine and you will see you are not alone. Apparently, a lot of DLP chips in Mitsubishi products are failing. With the low price of projectors these days, your best bet is replacing it. If you want to repair it yourself, the chip will run you about $200 to replace and may require soldering.
Hope that helps,
Bax
Nov 10, 2013 | Mitsubishi EX240U Projector
Display is turned sideways on monitor
You probably have the option to turn the picture at the monitor. Try going in the device's control panel through the computer and look for monitor rotation
Oct 29, 2012 | HP "View Sonic Pjd5353 1080P Front...
I am getting white spots that are appearing on the display image. It started out with one but now there's more every day. Is this fixable? Is there dust maybe ibside the lens? Is the bulb going? The...
I feel Most of DLP's getting this issue. Please tell me If the black & white dots are blinking....
To see it you need to put very clearly focused A4 sheet. If some dots are blinking .... most of time DLP chip is bad or getting bad.. IF can please upload a very clear picture......
Jul 30, 2011 | Optoma DLP Projector Multimedia Projector
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Flickering dots on Benq PB6200 projector.
it's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Oct 04, 2009 | BenQ PB6200 Multimedia Projector
Black dot appears in middle of screen when watching a movie
we changed out the light buld... now it works fine.. funny thing was projector was brand new just out of box... you could see first thing there was a brown spot in the center of the buld creating the spot apparently after it heated up.... thanks again
Aug 05, 2009 | Sharper Image 1617293 Projector
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
HP "View Sonic Pjd5353 1080P Front Projector, 300 Inches - Black" Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
