Question about Radio Communications
I have a cobra 148 GTL and I would like to know if you can install an external frequency counter on it and if so how?
    Top Expert:
  • 14,553 Answers
It can be done and is like a 70-80 parts cost---Google the item or look at the several places that sell radios like the 148 who also sell a freq counter for it.
Posted on Dec 06, 2012
  • 9 Answers
SOURCE: cobra 148 gtl channel mods
contact me i can mod your radio for 65.00
Posted on Dec 06, 2008
First take a jumper wire and connect it to the DC Ground of the input of the radio then touch it to the TX pin on the radio if it does keyes up then its in the mic or mic cord on the end of the mic plug or where it goes into the mic cable goes up inside the mic. If the radio don't key up at all then check the main voltage regulator chip one pin will have 8 volts transmit and another pin will have 8volts recieve. If you get no switching DC voltage on the regulator then its bad and needs replacing there is also a known bad capacitor in the radio thats only 10 volts change it to 25 volts at the same capacitance.
Posted on Jan 08, 2008
SOURCE: frequency counter keeps going off frequency
i was told that i have a couple of chips going bad
Posted on May 30, 2008
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
  • 773 Answers
SOURCE: Cobra 1000 GTL by Dynascan
This is a complicated modification. I have never done it to a 1000 GTL, but its done basically the same in all radio's.
I don't recommend doing it, especially since I am not 100% sure on how exactly to do it. I have never been in a 1000 gtl. If I had one in front of me I could tell you for sure how to do it.
If the reason for Variable power is a linear, just a swing kit in for the dead key you need, most likely 2 watts, and leave it.
Here is how to do a variable power mod. this is assuming the swing mod is done the same to this as a cobra 25/29 or uniden 68/76 etc.
If you would like to try it, here it is.
You get a TIP31 transistor, Radioshack has them.
Where you put the swing mod in the radio, which is a cap and a resistor, you put the TIP31 and cap. A 47uf cap works fine.
With the resistor facing you, and the tab in the back away, solder the cap to the transistor. the leg with the black stripe goes on the right most leg. then the other goes to the center leg of the transistor.
Solder a wire on the left most leg, long enough to reach the front of the radio. Now solder the 2 legs that don't have the wire on it, in the place where you would put the swing kit, with the black stripe on the cap facing the back of the radio usually.
Remove the wires from the RF gain and solder them together.
Now solder the wire from the transistor to the center tab.
Remove VR6 and solder a wire from the top tag of the RF gain to the top connection of VR6 that you removed.
Then connect a wire from the bottom tag to a ground point. The side of a tuning can works fine.
Take a piece of shrink tube and put it over the TIP31 so it does not ground against the heat sink, that would be bad.
This is done basically the same in all cb radio's.
Posted on May 03, 2009
Transmits off frequency
did you put it on a frequency counter? they can be set back on freq. if you know how to set it. how old is it? I would send it back to where I got it and have them fix the problem.
Jan 23, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 25 wx st FC 347 wiring
Just about all fc 347 come with instructions on how to wire it to the radio.
Jun 23, 2012 | Cobra 25 Wx St Sound Tracker Cb Radio W/...
FC-347 on a cobra 25 wx st
try to follow those direction as much as you can and if it doesn't work then try it a different way. Remember you need a power source and a source for the light to work.
Jun 23, 2012 | Galaxy Radios Fc-347 Frequency Counter For...
Cobra 148 gtlcobra 148 gtl DX
http://www.cbtricks.com/radios/cobra/148gtl_dx/index.htm
Nice choice of radio i have the Grant LX Uniden which is roughly the older version.
This site may be of interest also if you choose the channel mod make sure you have the right PLL. http://www.radioaficion.com/HamNews/mods/mods-cb/2428-uniden-grant-xl-mods-pll-agc-power-clarifier.html
Nov 16, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Not transmitting good at all on ssb the power come back
Did you have your radio "peaked?" If you turn a Cobra Sideband radio up to much it may be great for the AM side but can crush the Sideband side. Make sure it is on frequency too. Use a frequency counter to check. Make sure your SWR is 1-1:5 and no higher than two. You may have to take it to a tech and have them but it on a scope.
Mar 07, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 won't stay on frequency, same frequency on all channels
If you have a frequency counter, and a set of TV repair tools,( a set of special screwdrivers) You can tune the transmit on it. I would not do this unless you are skilled in such things.
The easy thing to do is take it to a cb shop. Usually you can find them at truck stops. They usually charge $30 for an alignment.
If you think you can handle it, I can try to talk you through it.
Apr 28, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 channles
CONTACT ME AT COBRAMAN148@GMAIL.COM I CAN HELP YOU OUT.
Mar 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148fgtl low power on am/ssb no swing all finals ok
try adjusting the L36,L38 to the highest reading on the external meter and then adjust VR10 TO 4 watts. If this doesn't cure the problem, you have a weak final transistor. Good Luck
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
