Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
How do i clean a Hoshizaki ice maker?
THe machine is 2 years old and it has never been cleaned. It started making a terrible noise so we turned it off.
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
Posted on May 07, 2017
  • Hoshizaki Master
  • 1,252 Answers
Normally there are instructions on how to properly clean and sanitize on the inside of the front cover. check there first.
Posted on Jun 07, 2014
refritech08
  • 149 Answers
SOURCE: Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Posted on Apr 23, 2008
  • 124 Answers
SOURCE: hoshizaki ice machine repair?
is water pump running? is sufficient water in the sump? they harvest when the harvest thermistor says lines are cold. lack of water and the thermistor gets to cold to quick and a premature harvest. no water or pump over plate and it gets to cold to quick. the water over the plate keeps temps up till ice can form. good luck.
Posted on Oct 30, 2008
farfield
  • 462 Answers
SOURCE: Hoshizaki ice machine with constant beeping every 3 seconds
I believe if you remove the thermostat wires and put them together and retry it you'll be making Ice, then get you a new thermostat. Please rate me accordingly and good luck.
Posted on Mar 20, 2009
cdarnell89
  • 16 Answers
SOURCE: need to clean an ice machine
http://www.hoshizakiamerica.com/manuals/KM-500M_E_serv.pdf
Cleaning Inst. start on page 52 and go to 56
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: We need help cleaning our Hoshizaki ice machine.
k well that will depend im not really an expert on it but i did clean 2 freezers so im thinking that theyd be pretty much the same...hope i can help. first of take all the ice out of the machine. since it looks nice and new im thinking that the put thought of cleaning into making it.so i think theres a drain in there. not sure how clean you want it just take a scrub pad and soap(if you find the drain) the rinse it out. not sure y you would want to clean it though.
Posted on Jan 28, 2010
Hoshizaki KML-450MAH ice maker wont start after clean up
If you did a cleaning cycle and used the bypass valve to clean between the evap plates, look for the micro switch on the bypass valve to be bad. It is a small switch attached to the by pass and keeps the compressor off during the cleaning process. I'd start there.
Jul 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Jun 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Ice Maker
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
308 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
