Question about ASUS PL-X31M - bridge
Power line does not connect - ASUS PL-X31M - bridge
    New Friend:
I have the same problem...
Posted on May 23, 2013
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
My fan motor terminal connection to wiring are all cut no color wire all live wire how do i connect it
no numbers, tags or colors on the motor leads or the wiring? Tracing each wire, investigating for clues may get you in the right path. A motor with a capacitor is wired so that two motor wires, (T1 and T2) connect to power (L1 and L2) and a third wire connects only to a capacitor, the other side of the capacitor connects to line 2.
If the motor has 4 wires, then two wires connect to power and the two brown motor wires connect to a capacitor.
Motors with a brown wire with a white line is the same wire as a white wire off the motor. This makes the sold brown wire connect to a capacitor by itself and the brown with a white streak or the white wire connect to the other side of the capacitor where a power line wire connects and the other power line connects to the remaining motor wire. Confused? Draw it out on paper as explained and draw what is actualy on your unit.
Apr 30, 2015 | Heating & Cooling
Red light dsl
You can try to:(if your Belkin is connected directly to the DSL line)
1-power router off
2-diconnect the DSL line from the router
2b-connect the DSL line to your* PC and test;if works then;
3-power on the router and connect the line back again.
2b*-if not call your ISP.
Sep 18, 2013 | Belkin N450 Wireless N Router
NO POWER OUTPUT ,THE LED LIGHT IS OFF
Check the line cord to see if it can carry power. Check the connection from the line cord to the power supply. It may be that the soldered connection is broken there and needs re-soldering. Check to see if it has any external or internal fuses that need replacing.
Sep 21, 2012 | Dell PWR SPLY,250W,PFC,HP,HIPRO Power...
CANT SEND FAXES THROUGH THE PC
1.The machine is not on-->You cannot send faxes if the power is turned off.Press [on/off] to torn the power on.
After a power failure or disconnecting of the power cord ,press [on/off] to turn the power on.
2.The telephone line is connected to the external device jack .
Reconnect to the Telephone ?Line Jack .
If you still cannot send a fax,there is a problem with the telephone line.
3.Cannot here the dial tone-->check that the telephone line si connected correctly to the proper jack,if so,then there is a problem with your telephone line.Contact your telephone line provider.
Jan 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Help connecting brother fax machine
1. Connect the handset.
Connect the curled handset cord to the bottom of the handset and to the left side of the machine.
2. Connect the power cord.
3. Connect the telephone line.
Connect one end of the telephone line cord to the jack labeled LINE on the left side of the machine. Connect the other end to a modular wall jack.
WARNING
 This machine must be grounded using a three-prong plug.
 Since the machine is grounded through the power outlet, you can protect yourself from potentially hazardous electrical conditions on the telephone line by keeping the power to your machine on when you connect it to a telephone line. When you want to move your machine, protect yourself by disconnecting the telephone line first, and then the power cord.
 Lightning and power surges can damage this product! We recommend that you use a quality surge protection device on the AC power line as well as on the telephone line, or unplug the lines during a lightning storm.
Dec 30, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I need help connecting my fax machine
WARNING
power cord.
1 Connect the handset.
machine.
2 Connect the power cord.
3 Connect the telephone line.
Dec 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Feb 14, 2010 | Cooper Industries Cooper Wiring 2158V 3...
I have a 2001 F 350 ford diesel . Started it up ,no brakes, no power stearing. Fluid on the ground, both pneumatic lines to brakes blown off. leaking fluid out of the power stearing line, blew connecting...
the hyrdra boost supplies pressure to these systems, that is done throught the power steering pump, the line or the pump is defective, I would replace both.
Jul 21, 2009 | Ford F-350 Cars & Trucks
Memory hold on CDX-CA400 CD Player
The correct wiring is constant power on the yellow wire, switched power on the red wire. I'm not certain why you weren't able to get it to work in this configuration; the unit needs power on both wires before it will turn on, but if you lose power on the yellow wire the settings will be lost.
Jul 31, 2007 | Sony CDX-CA400 CD Player
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
See all ASUS PL-X31M - bridge Questions
ASUS PL-X31M - bridge Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
