Question about Canon Faxphone L170 Monochrome Laser Fax 0815B002AB
"supply Rec Paper Cassette" canon L170
Filled paper try - 100 sheets. Printer is 2yrs old, been working fine
  • 29 Answers
Tip up L170 and ensure paper detect flag is not broken or dislodged
Posted on Dec 28, 2014
SOURCE: and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Posted on Sep 17, 2007
SOURCE: Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
Posted on Oct 25, 2007
old marine
  • 2005 Answers
SOURCE: Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Posted on Oct 16, 2008
xptareq2000
  • 1447 Answers
SOURCE: supply rec. paper when i insert paper then rec. paper jam
Your copier feed roller clought is not active wash it and then solve
Posted on Jun 11, 2009
SOURCE: Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Posted on Jun 16, 2009
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon imageCLASS D860 All-In-One Laser...
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Canon d680
try new cartridge. are you using new or remanufactured?
Nov 09, 2007 | Canon imageCLASS D680 Laser Printer
Can't change image quality
The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
Sep 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon Faxphone L170 Monochrome Laser Fax 0815B002AB Logo
107 people viewed this question
old marine
old marine
