Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
I have Emberglow ventless gas logs (set to burn on porpane gas). First I connected them to a propane 20 lb tank and they worked perfectly (for about 2 hrs. until the tank lost pressure). Then I switched to a 100 lb. propane tank -like the manual recommends- and I get the pilot to ligth, but it will not stay on to start the logs. The propane tank is connected with a POL connector and a 1/2 psi regulator (11" CW) to a 5ft. 1/4" hose and a 3/8" connector (commercial kit) to a 1/2" black iron pipe that goes into the house.
  • Heating & Co... Master
  • 3,315 Answers
It needs 14'' wc to work , hose could be too small for load .
Posted on Dec 07, 2012
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Posted on Sep 17, 2007
  • 70 Answers
SOURCE: I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Posted on Oct 24, 2009
  • 75 Answers
SOURCE: pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Posted on Nov 08, 2009
SOURCE: I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Posted on Jan 03, 2010
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Propane ventless wall heater pilot light is to big
You have the correct pressure equaliser on the propane bottle giving the correct pressure.
  1. The minimum gas supply pressure must be 1" water column (249 pa) above the manifold pressure printed on the appliance data plate
  2. The maximum gas supply pressure must not exceed 14" water column (3487 pa or 34.9 Millibars)
Feb 10, 2018 | Heating & Cooling
I have a mod. REH-18-N 005843 ventless heater (gas) can I change it to porpane? How safe is in a reck room area?
you will need a conversion kit from natural gas to LPG. For room sizing you will need to look in the manual
Dec 14, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Have a comfort glow heater ventless natural gas. need to know where to get the little part that the pilot light flame comes out of. need a new one. cleaned the stove last night. after, the pilot light...
Look for a small hole or two in the part the pilot flame comes out of. These may be partly blocked. They allow air to mix with the gas for the pilot.
Mar 31, 2010 | Heating & Cooling
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Jan 03, 2010 | Desa International Unvented Gas Space...
After about 5 years with no problems, the emberglow vent free gas logs are not igniting. the gas is coming out as i can hear it, but the ignite switch doesn't have any effect. if i hold a lit lighter in...
Sounds like a bad pilot sensor called a Thermocouple. It is a copper tube that goes from the gas valve to the pilot assembly. It is the smaller of the two tubes. They are available at better hardware or farm stores. It is best to unscrew it from the gas valve and pilot assembly and bring it with you when you shop for one. It is something any mechanically inclined homeowner can replace.
Dec 03, 2009 | Desa International CCL3924PTA 24" LP Gas...
Pilot light goes out when I turn the the dial to "On"
Hi no thermocoples are made to be exchanged never come across that in 30 years of gas fitting
Nov 16, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Will not light, sems like gas is not geeting to logs
Try taking a can of compresssed air and blow it in the pilot assembly wait about a min and try to light it. it is normal if it smells funny.
Nov 01, 2008 | Desa International CCL3924PTA 24" LP Gas...
Heating & Cooling Logo
417 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
