Question about Refrigerators
Freezer not working properly
The freezer gets major ice build up and causes noisy fan noise. After I shut down and defrost it works well again for 4 to 5 days till ice builds up again. I can feel ice buildup behind the back of the freezer panel as well. Is it a thermostat problem. What part might fix the problem?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 07, 2012
  • 2 more comments
  • toli65 Dec 09, 2012
    It's a 7 year old Maytag Model # MTB2195 AEW. I would love to know what it might cost to fix so that I could decide whether to fix it or toss it. Can you tell me if you think it is a thermostat problem and if it is worth fixing??? Thank you.
  • Richard Roth
    Richard Roth Dec 09, 2012
    You can fix it. You need to replace the defrost thermostat and it is an easy job to do. Here is the part to order.http://bit.ly/12fHbJc Here is a video to walk you thru the process.
  • Richard Roth
    Opps, look at this video!
  • Richard Roth
    Sorry about the wrong video.
  • 183 Answers
SOURCE: ice build up on fan
problem is most likely caused by water overflowing from ice tray and then freezing to motor, hold light switch in and see what happens when tray fills up. Regards Advisor
Posted on Aug 23, 2007
  • 10 Answers
SOURCE: my frost free fridge freezer
I would start with a 24 hour full defrost,
if the problem reoccures then it is more likely thermister fault
Posted on Mar 19, 2008
SOURCE: Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Posted on Jan 07, 2009
  • 219 Answers
SOURCE: ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Posted on Mar 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: frost building up in freezer cause refridgerator to get warm
Your refrigerator has a main control board part number WR55X10656 if the board is not working properly normal functions of defrost will be skipped and frost buildup will decrease cooling. The cost of the board is expensive and you may want to get more advice to get answers. Control, boards have been a real nuisance for the so called modern refrigerator. If under warrant it would be helpful. You can replace the board yourself and save the cost of a repair technician service. If you like I will help you get through this, Thanks, Sea Breeze
Posted on Mar 26, 2009
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
Noisy freezer, could be fan or condenser
I wouldn't defrost it. It could be a couple of different things causing this, from a bad defrost thermister to cubes overflowing out the back of the ice bin. Try removing the ice bin and clearing the cubes off of the dispenser motor cover. The fan will eventually sling the ice formation off.
Feb 14, 2010 | GE Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Ice building up on freezer coils
sounds like the fan for the freezer is not working
Apr 03, 2009 | GE GSS25LGM Side by Side Refrigerator
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Drain line froze.
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Freezer fan is very noisy
What knid of a noise is it making. A high pitched squeal tells me the bearings in the motor are bad and you need to replace the fan motor obtainable through a dealer. If the noise is more of a grinding noise it could be a simple mater of the fan blade hitting some ice build-up. Defrosting the area of the fan motor with a hair dryer will melt the ice.
May 16, 2008 | GE PTS22LCS Top Freezer Refrigerator
Ice build up on fan
Feb 08, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
