Question about Tappan Kitchen Ranges
Tappan Pro Design, model number TGF362BBBA, oven reset
Tappan Pro Design, model number TGF362BBBA. Oven will not come on when you push the buttons. Gas has been off and recently reconnected. Buttons for timer, clock set and clean cycle beep and look like they would work, but not the cooking functions. Is there a way to try to reset the oven, or is it likely another problem?
siawolf
  • 749 Answers
SOURCE: Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Posted on Oct 15, 2008
  • 7 Answers
SOURCE: GE LR44 model JGBP34 doesn't sense Bake/Broil/Clean buttons
Circuit board repair is your only alternative to shelling out $200 for a replacement. Take the control box out of the stove and remove the top board, which is just relays and interface connectors to the AC power and bake/broil burners. Under this is a complex circuit board, also to be removed. You have to unbend tabs to do these removals, and make sure that all the inter-board connector pins are properly mated when reassembling and rebending tabs. On the underside of the circuit board I found corroded spots under each of the 3 electrolytic capacitors on the board. Very suspicious. I replaced the caps and had to patch two traces on the board with jumpers, and this fixed the problem! You may as well try this (or have a nerdly pal try it) since you have nothing to lose and possibly $200 to save.
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: had the oven set to
Over on the applianceguru.com forum someone posted this problem and the gurus there said it's the control board. You can order the part online and replace it yourself, it's probably around $150-$200 depending on where you get it. You may find a better deal on ebay too.
Posted on Nov 28, 2008
  • 530 Answers
SOURCE: Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
Posted on May 28, 2009
fixyourboard
  • 310 Answers
SOURCE: I have a GE XL44
This is a failure with the clock module. You can replace it with a new one, or fixyourboard.com rebuild it to save you some cost.
Posted on Aug 14, 2010
Testimonial: "Great feedback, now I know part to get. Thanks"
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
Tappan gas range manual
I am the manual on this one. A simple design. Oven works like this. Power is going to the ignitor and gas valve when oven is on. The ignitor must draw at least 3.5 amps to open the bimetal safety valve. If it looks dim orange chances iz that puppy is too weak to open the gaz safety valve.
Dec 31, 2012 | Tappan Kitchen Ranges
Looking for schematics for Tappan Self Cleaning Oven 1989 sold by Montgomery Wards
Mike,
I need parts for my Tappan 1989 Self Cleaning oven and I can't read the model number anymore. What is your model number?
moparlou@gmail.com
Jan 15, 2011 | Microwave Ovens
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
63 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
