Question about Saws
I have a craftsman compound miter saw, 10 " Model # 315.285410 that just stopped ... no power ... do you think it is the cord disconnected from switch? Advice?
rowdy45176
  • 2176 Answers
SOURCE: change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Posted on Jan 26, 2009
efs_perpends
  • 1996 Answers
SOURCE: Need manual for Delta 10'' compound power miter saw MS 250
If you can't print from your computer, or local library, find a local print shop or copy shop that is willing to download and print a .pdf file for you.
Then go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: I am looking for an owners manual for a Delta compound miter saw
Got it. Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number, use the type 2 on the next page and under instructions use the one beginning with "en" it is 21 pages long but it is there. If I have helped you with your question would you please rate my response accordingly and Thank you.
Posted on Sep 09, 2009
  • 333 Answers
SOURCE: I need to unlock the arm on my craftsman compound
there is a black round pin towards the back top. Pull it out
Posted on May 02, 2010
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
Makita miter saw has no power
Disconnect it from the wall outlet. Use a VOM set to continuity (i.e ohms) connect one lead to each of the power cords. Depress the start switch. If switch and circuits are good you should get either a low reading or just 0.0. IF you get no reading or really high reading the unit has an internal fault and more troubleshooting will have to be done.
Aug 10, 2014 | Makita 10" Dual Slide Compound Miter Saw...
How do I replace the spring in the lock off lever?
This is page 28 of the manualhttp://www.manualslib.com/manual/490926/Craftsman-113-235110.html?page=28#manual.
Nov 27, 2013 | Craftsman 10" Inch Miter Saw Sears Model...
I am Looking for a miter gauge (which is an accessory) for a old craftsman model 113.244512 band saw. Is there any around out there?
You may look up to ebay or search on google. I actually order band saw parts with www.bandsawparts.com but I think they don't have the miter gauge for your bandsaw model.
Dec 20, 2012 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
Craftsman Miter Saw stopped working
Are you plugged into a GFI receptacle? If so maybe you have to reset the GFI. I would also check for loose wires on the switch or plug and make sure your cord is good.
Aug 20, 2012 | Craftsman Saws
Craftsman 10 in miter saw just stopped working...not getting any power. Any ideas?
Check the brush under the black caps on the side of the motor. Make sure the plug is unplugged while you are checking it out.
Feb 04, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Craftsman 12 in. Compound Miter Saw w/Laser Trac stopped working
the hole saw or just the laser part , and ck to see if it has a reset button on the end of motor if so push it in until clicks ,
Jan 02, 2009 | Dewalt DW746X 10" woodworker's table saw...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
138 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
