Question about General Electric WCVH6800J Front Load Washer
I have model WCVH6800J1MR. It will not fill during normal cycles.
I have model WCVH6800J1MR. It will fill fine on the basket clean but it will not fill during normal wash cycles. So the solenoids should be working fine. I would think that the basket clean cyle also uses the water level sensor so I would think that is fine. Running t02 check I get E22. Well I know there is a fill problem so this didn't help. Test t06 is normal, it fills to all 3 levels then empties. Test t12 seems OK on pdt and ddt but doesn't seem to do bdt and Fdt. I do not see either of those chambers filling. I don't use bleach or fabris softener so this doesn't really bother me. However, would that cause the wash cycles not to fill the wash at all? Intake screens are clean. I cleared the t02 error code (E2) and tried again. Help!!!
  • Dave Muri Dec 06, 2012
    Sorry, there was a typo, the t02 error is not E2 but E22. Both hot and cold seem to work on t12 tests. No filling at all on any temperature with a normal wash cycle.
  • Dave Muri Dec 12, 2012
    This Washer FOOLED me. It would not fill on the tap cold setting, the cold setting nor would not fill on the "WARM" setting. Since it would not fill on the warm setting I thought the hot water wasn't working either (isn't warm a mixture of hot and cold?). So it does fill on HOT and Sanitize settings as well as basket clean and the diagnostic tests- all of which use hot water. So it is simply the COLD water solenoid that is bad which is the most common problem. Sorry for the wrong symptoms but I really did think the WARM setting was turning on both hot and cold water - the machine must warm it a little itself.
3 Suggested Answers
  • 44 Answers
SOURCE: How to start my WCVH6800J1MR
Do a diagnostic test, first thing. Free and easy and the machine will almost diagnose itself. Here's how: http://www.fixya.com/support/t9576766-found_small_part
Posted on Jul 28, 2011
  • 44 Answers
SOURCE: Have a GE Model WCVH6800J1MR that doesn't fill
Cool thing about these new computer controlled appliances is that they diagnose themselves. Easiest way to find issues is to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Post back once you have the codes and we'll see about next steps.
In addition to t02, you should definitely do "t08" and "t09" tests to check the hot/cold water valves. chris_in_ma_7.jpg
Clean cycle stops and rl appears
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2010 | Kenmore HE2 Plus Front Load Washer
I was running the clean cycle on my Kenmore front loading washer and it keeps stopping and reading rL. It wasnt having any probs working on reg cycles, only when I was trying to run the clean cycle. What...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore he plus did not drain and spin, I tried to start a the clean cycle and there is a code "rl". what is wrong?
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
My washing machine is a kenmore model W10071750 and it keeps flashing rL. I cannot find this error code in the manual. I tried reloading it and restarting it. That did not work.
It may be a long shot, but it's worth a try before engaging in an expensive service call. Pull the plug - count to 60 - replug. Mine is washing again.
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
My Kenmore HE2 plus frontloading washer is flashing a ''rL'' code when I try to run the cleaning cycle. Nothing is in the washer, and I've tried several times. How do I clear it?
Sep 15, 2009 | Kenmore Washing Machines
HE2plus. I keep getting rL on clean washer cycle.
Mar 03, 2009 | Kenmore HE2 Plus Front Load Washer
General Electric WCVH6800J Front Load Washer Logo
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
