Question about HSM SECURIO B32 Shredder
Hsm securio shredder will not shred, just feeds then reverses
2 Suggested Answers
  • 45 Answers
SOURCE: hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Posted on Apr 16, 2009
How do you fix the Shredstar PS817c that is stuck in reverse?
If you want to try to resolve the problem yourself I suggest you use their Customer Service to help answer your question: Online Service Portal HSM of America
http://www.hsm.us/service/online-service-portal/
Jul 11, 2014 | HSM 1030 shredstar PS817C Medium-Duty...
How can I clear a paper jam on a hsm securio b32 shredder when the reverse function does not clear it
On most shredders ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 16, 2013 | HSM SECURIO B32 Shredder
How can I clear a paper jam when the reverse function does not work
Oct 16, 2013 | HSM SECURIO B32 39mm shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Turns on and shreds for about half a page, then automatically reverses.
My shredder is jamming. Would oiling it help. I have never did anything with it until now it needs help.
Nov 09, 2009 | HSM 125.2hs Shredder
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
Apr 13, 2009 | HSM 225.2hs Shredder
Hsm 125
Sounds to me like a the main control board is fried. That smell was probably a resistor or a rectifier burning. The fact that you hadn't oiled the shredder in 3 years didn't help, probably put an extreme load on the drive motor. You might be better off, shopping for a new shredder, unless this is a high end industrial strength model.
Sep 05, 2007 | HSM 125.2hs Shredder
HSM SECURIO B32 Shredder Logo
37 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
