Question about Altec Lansing VS4621 Speaker System
The left speaker on my VS4621 is not working - Altec Lansing VS4621 Speaker System
I just picked up a JVC r33 receiver. Only three speakers work both left and right B speakers work. And only the left A speaker works. IS there a web site to trouble shoot?
Try one of the speakers that you know works in the left B to see if it works. If it does, then you know you have 1 dud speaker which could be only a broken wire or bad connection. If the good speaker doesn't work, try checking all the connections and balance positions to see if the speaker left B output is actually set correctly.
Apr 08, 2015 | JVC Audio Players & Recorders
How do I stop right satellite speaker from emitting a loud buzz once I plus it in to the sub woofer?
Your speaker may be blown. It doesn't have to be fiscally blown maybe you just burned or disaligned the coil/s try a different sub or check your amp it could be blown. Defective parts in an amp could emit weird sounds to your sub.
Jan 07, 2015 | Altec Lansing VS4621 Octane 7 2.1-Channel...
Why is there a loud humming/buzzing coming from speakers?
most of the time this is caused by a bad ground. Check all cabling from and to the right side satellite and the sub woofer.
May 26, 2014 | Altec Lansing VS4621 Speaker System
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Need maual for altec lansing vs4621 speakers
My Dell Vostro computer does not recognise my Logitek speakers
Dec 28, 2012 | Logitech X-530 Computer Speakers
The FX4021 'speaker right' don't work good, depend de frequences, is possible repair it or replace it for another 'speaker right' (a clone) I live in Barcelona (Spain) and the 'Altec Spain' (Memtec...
Hi there , not long ago I was having issues with my VS 2420
I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following
Contact: nicky.cook@alteclansing.com , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Dec 24, 2010 | Altec Lansing FX4021 Computer Speakers
My left speaker doesn't work but my right speaker does. The cord to the left speaker is plugged in all the way.
Open the "Volume Control" applet & make sure the "Balance" setting is set in the middle of the scale. This way sound will go out through both speakers.
Nov 09, 2009 | Altec Lansing MX5020 Computer Speakers
DENON PMA520 Amp. Suspect left channel not working as set bias to all left and get nothing out of left speaker. Right speaker working. Tried interchanging speaker connections and get same result from...
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Jul 27, 2008 | Denon Audio Players & Recorders
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
Left speakers not working
tell me what sound card you have
Nov 24, 2007 | Logitech X-530 Computer Speakers
Altec Lansing VS4621 Speaker System Logo
103 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
