Question about General Washing Machines
I have model WCVH6800J1MR. It will not fill during normal wash cycles.
I have model WCVH6800J1MR. It will fill fine on the basket clean but it will not fill during normal wash cycles. So the solenoids should be working fine. I would think that the basket clean cyle also uses the water level sensor so I would think that is fine. Running t02 check I get E22. Well I know there is a fill problem so this didn't help. Test t06 is normal, it fills to all 3 levels then empties. Test t12 seems OK on pdt and ddt but doesn't seem to do bdt and Fdt. I do not see either of those chambers filling. I don't use bleach or fabris softener so this doesn't really bother me. However, would that cause the wash cycles not to fill the wash at all? Intake screens are clean. I cleared the t02 error code (E2) and tried again. Help!!!
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: I have a GE front load washer WCVH6800J1WW that is
Here is the information you requested. This is straight out of the service manual for your machine.
E38 = Dispenser Error
Correct reservoir is not found and 8 switches are seen when motor is running. Check dispenser - t12 (Note: Do not unplug connectors from dispenser motor unless replacing.)
Happy Holidays
Posted on Dec 11, 2010
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Clean cycle stops and rl appears
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2010 | Kenmore HE2 Plus Front Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine is a kenmore model W10071750 and it keeps flashing rL. I cannot find this error code in the manual. I tried reloading it and restarting it. That did not work.
It may be a long shot, but it's worth a try before engaging in an expensive service call. Pull the plug - count to 60 - replug. Mine is washing again.
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
Out of balance
Did your clutch pulley use the upper One-Way Bearing ring?
What are the first two digits of your Serial Number of the machine?
What is the history of the Clutch install? Did the unbalance issue continue right away with the new Clutch Install?
How much rust did you find on the Clutch Pulley and the Upper One-Way Roller clutches bearing ring if used? Any Pic’s of the old Clutch Pulley?
If you shut off the water source valves to the machine and release the top the washer so you can lift the washer top and observe the wash basket rotating CCW at 50 RPM during the water fill part of the wash cycle.
Start a quick wash cycle and lift the washer top to observe the wash basket rotation CCW. The wash Basket will rotate CCW at 50 RPM. You can go into Service Mode and observe on the LED console FAV6800A machine. Not sure about the FAV9800A LCD flavor of the machine.
Do the tumblers rotate slightly during the water fill part of the cycle?
The machine may error out with NF for No Fill don’t worry about that I just want to determine if the tumblers are rotating during the CCW/Spin direction of the wash basket. You may have to put some dry laundry in the wash basket to help with the observation.
Let me know what you see……..Rich
Jul 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
HE2plus. I keep getting rL on clean washer cycle.
Mar 03, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Top General Washing Machines Experts
Dan Webster
Dan Webster
Chris Goulet
William Miller
William Miller
Are you a General Washing Machine Expert? Answer questions, earn points and help others
