Question about LG WM2240CW Washer
How to fix washer machines with error code te
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
buffalonyman
  • 1865 Answers
SOURCE: tE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Posted on May 06, 2009
  • 4 Answers
SOURCE: LG washer tE error code
A "tE" error code is more than likely the "thermistor". Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place.
Posted on Jun 02, 2009
ftw1952
  • 10319 Answers
SOURCE: How I fix an error code on a LG wm2669hna washer
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Posted on May 18, 2010
  • 106 Answers
SOURCE: My washer has a te
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Posted on Mar 07, 2011
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
LG Front Load Washer
te is a error code for a bad thermister. it senses the temp of water in the tub. this needs to be replaced
May 01, 2014 | LG WM-2277HW Front Load Washer
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
TE error code problem How to fix the thermistor
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | LG WM-2277HW Front Load Washer
My washer has a te error code, lost the owners manual, what does the te code mean and how do we fix it?
Mar 06, 2011 | LG WM-2277HW Front Load Washer
How I fix an error code on a LG wm2669hna washer that says TE error
May 17, 2010 | LG WM-2277HW Front Load Washer
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Apr 27, 2009 | LG WM2277H Front Load Washer
LG WM2240CW Washer Logo
106 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
