Question about LG Blu Ray HB966TRW Wireless Home Theater System
Rear speakers not working
Two small speakers not working.
    Sergeant:
  • 256 Answers
Output transisters are probally blowin
Posted on Dec 06, 2012
Rain got into my truck window now my speakers has stopped working...what should i do?
Could have damaged the speakers or the radio or both.
You could pull a door panel and connect a small used speaker to see if the radio is producing a feed to the door.
Jul 03, 2012 | 2004 Chevrolet TrailBlazer
Why rear speakers of my 2002 holden astra not working?
It is almost certainly a wiring problem. Try the following:
1 Carefully remove the radio from the dash board (might have to push a small tool into each side of the radio to un-click the safety tabs).
2 Check the 8 pin plug & socket on the back of ther radio. Rear speakers are often pins 1 & 2 (right) and 7 & 8 (left).
3 Temporalily connect any speaker to pins 1 & 2. Repeat for 7 & 8.
4 Check the connections at each of the rear speakers.
5 Run 4 new wires through the car to the rear speakers - not an easy job, just take your time ;-)
Nov 25, 2011 | Blaupunkt Car Audio & Video
Rear detection devise is off and cannot be turned on
does the light on the switch for the rear sonar stay on?my experience with these is nine times out of ten the small speaker located behind the gauge assembly that emits the beep goes bad and puts system in a fail safe mode.if im not mistaken part is around 50.00 and is fairly easy to replace.please let me know if this helps.
Feb 13, 2011 | 2005 Nissan Quest
Rear speakers L and R not working and MD in and out not working on my Sony STR-DB940
I'm guessing these are separate issues.
Has either one ever worked and stopped suddenly?
From the manual:
"No sound or only a very low level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see page 33-35).
>>> Adjust the speaker volume (see page 72).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 20)."
Be advised that using any Tape Monitor loop (that's what the MD/DAT is) disables any digital sources. Not that that would explain the rear speaker failure. Analog sources can still be processed into various surround modes.
Any Tape Monitor use requires at least a live INPUT to hear anything.
May 29, 2010 | Sony STR-DB940 Receiver
It started with the rear speakers on my 2001 Audi A6, all of a sudden, making a very loud distorted/cracking sound. Now, rear speakers do not work at all. Any clues as to what has happened and the what is...
try connecting them to a small radio or tape player to see if they still work ?? if they appear to work ok on a small set then i would be inclined to check the colours on the speaker wires then rmove the radio and try connecting another known to be good speaker to the output on the radio and if that works ok then renew the feed wires to rear speakers because thats where your fault would lie for whatever reason like a mouse got in or seat crushed the wires or whatever
Dec 01, 2009 | 2001 Audi A6
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Jun 29, 2008 | Samsung HT-X50 System
Can i use small satelite speakers with my big front speakers?
Hi, I asume your setting up a home theater with five speakers a center left and right and rear surrounds don't know if you have a subwoofer. The large speakers in the front will work fine if you set the amp to large front speakers the bass will be sent to these. If you have a subwoofer set, the amp to small front speakers and the bass will be directed to it. Also try to get a center channel speaker that sounds somewhat like your large speakers.
Feb 14, 2007 | Yamaha AX-596 Amplifier
LG Blu Ray HB966TRW Wireless Home Theater System Logo
175 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
