My Whirlpool LGR7647 will dry ok. Everytime it drys, it smells like gas. and only when it runs. It has completed 2 or 3 loads like this. The gas supplier says there is no leak. Any ideas?
SOURCE: i run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
SOURCE: machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
the automatic feature could be the problem. the damp sensor could be faulty. the timer would run even though the clothes are still damped. it is supposed to stop while the clothes are still wet.
tnx 4 using fixya,
drcool
SOURCE: Dryer smells like gas when running and only drys some of the time
repl/ coils ,, thats what usually happens
SOURCE: My Kenmore dryer does not dry clothes completely and
This is dangrous you should call a repair man.
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
*it is a lgr7646
