Question about LG Televison & Video
No power I have a LG 50PG20 Plasma. It does not have any power. I changed 5 capacitors that were bulging on the power supply board 10v and 50v. I tried to power it on with no results. I looked at all the capacitors on the other boards and they seem to be fine. Is there anything else I can look for that can solve this issue. Thanks
    Top Expert:
  • LG Master
  • 14,553 Answers
When the caps got real bad they may have taken another part on the power board---also see if any of the foil traces on the bottom of the board were damaged by the caps---some will actually leak a material that can eat the board foil off.
Short of that Google the model number with "parts" as I know one large seller who lists almost every LG set ever made and all the boards that are used in them--if you gamble-try the power board first.
Posted on Dec 06, 2012
  • James Dec 06, 2012
    Thanks I will look in to that
SOURCE: LCD turns off\on repair
You can also find this part for the Samsung LN-T4665F at:
http://www.partstore.com/PartSearch.aspx?PartNumber=BN44-00168B&x=19&y=10
If you have different TV do a search on the model number...
Posted on Sep 11, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a gateway 42"
Hi
Its not a power supply issue, but an issue related to the D-board on your TV. There would be swollen/bulged capacitors on this board. To check this you'll need to remove the back panel of the TV. Check the connections to and from the D-board. Make sure the lamp connections are fine and ballast is not burnt. Also check if all cooling fans are working.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
budmrtn
  • 11361 Answers
SOURCE: I own a PANASONIC TC-32LX85
Not all power supply used 3300uf/10v, it can have many many values, he was using generic term for typical value.
You should get the service manual for this TV first. You then need to do some voltage checking. Please read and undertand some basic how the LCD flat panel TV works so you will get some unsderstbding how it works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 19, 2010
Loud Pop and the Screen went dead on a LG 42PX3DCV plasma TV. 5 years old so out of warrenty. I took the back off the tv and checked all the ceramic resistors and the resister on the Y-SUS board has...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helpout in solving the problem....
May 31, 2011 | LG 42PX3DCV 42 in. Plasma EDTV
My lg 50"plasma tv turns
Look for Bad Capacitors,they will be vented,puffed up on Top if you see any like that they are Bad 1000uf 16v, 2200uf 10v, 3300uf 10v.
May 30, 2011 | LG 50PG20 50 in. Plasma HDTV
My tv doesn't work. When we turn it on it doesn't shows nothing on the scream, it only stays grey. Also it starts to go on or off by it's self.
Look for Bad Capacitors on the Power Supply board,they will be vented or puffed up on Top.
1000uf 16v 2200uf 10v 3300uf 10v
Apr 08, 2011 | LG 50PG20 50 in. Plasma HDTV
I have lg plasma i heare clicking sound when i turn on and there still picture for few minutes and it's gone but i could still heare the sound clear.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 18, 2011 | LG DU-42PX12XC 42 in. Plasma HDTV
I have an LG 50PG20. There was just a power surge, and now the TV power will not turn on. The lower left button - which is blue when power is on - is a blinking red. The TV also went 'black' while I was...
You should check the capacitors on the power supply board and others. There were nine bulging/busted caps on my power board that I just replaced for $6.61. Works just like new! Someone who knows how to solder can do it.
Aug 19, 2010 | LG 50PG20 50 in. Plasma HDTV
NO power to the my 50PG20. It just quit working.
Open the back of the TV and look for bulging/busted (oozing goo) capacitors on your power board. I just replaced 9 of them for $6.61 and the TV is just like new. There are plenty of videos on YouTube about removing and soldering caps.
Aug 08, 2010 | LG 50PG20 50 in. Plasma HDTV
No power, tried a new power cord, still no power
Ur tv have any power lite flashes on the front power LED lite on the screen pannel?Yes,than the power supply board have dead leakage parts capaacitors,they bulges up on it top or puff off on it tops.U know basic electronic,soldering equipments and know soldering?Replaced those dead leakages gas capacitors on the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | LG 50PG20 50 in. Plasma HDTV
Plasma Television won't turn on
Hi
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Jul 02, 2010 | LG 42PQ30 42 in. Plasma TV
LG PLASMA TV MADE A LOUD POP NOISE NOW PICTURE IS SNOWY
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
Hope this helps
Jun 16, 2010 | LG 42PC3DC 42 in. Plasma HDTV
Televison & Video Logo
386 people viewed this question
Computer Repairing
Computer Repairing
