Question about Husqvarna Garden
Husqvarna 36 cc chain saw wont start changed spark plug cleaned carb
  • Husqvarna Master
  • 1,807 Answers
Does it have compression.? Does it have a spark.? Is fuel getting into the cylinder.?
Posted on Feb 05, 2013
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
  • 211 Answers
SOURCE: husqvarna chain saw stalls
hi charlier 421
I think the small holes from the Venturi wall of the carb are clogged.To clean them you need carb disassembly.Near the needle there is a tehnological cover,under the diafragm(fuel pump).Taking off it you will see some small holes maiking conection with Venturi wall.Used ompresed air to clean them.
best wishes savumihai71
Posted on Dec 01, 2008
  • 17 Answers
SOURCE: Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Posted on Jan 03, 2009
  • 7 Answers
SOURCE: my poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Posted on Feb 25, 2009
  • 398 Answers
SOURCE: 353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Posted on Feb 27, 2009
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Dec 06, 2012 | Husqvarna Garden
Wont start replced spark plug cleaned carb
If you have good fuel and a good spark it may be a mechanical issue, remove the muffler and check the condition of the piston face through the open exhaust port, any signs of damage or scuffing and it will need to come aprt to assess the damage, if all looks good it may be a crank seal leaking, the 36 was prone to blowing the seal behind the flywheel, also check the flywheel key in the flywheel has not sheared knocking the ignition timing out.
Dec 06, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 181 se wet plug wont start -low is 1/4 turn -high is 1/4 turn- checked diaphgram - checked & cleaned carb
i would remove the muffler and clean the screen inside they build up with carbon and more so when you have carb problems
Aug 12, 2012 | Husqvarna Chain Saw Handle Models 181 281...
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 455 chain saw will not start
Check to see if you have a spark pull the plug out plug the cap back on it hold it to the head and pull the cord see if it sparks It likely will most of the time with small engines its the carburator and what it needs is to be cleaned they sit around and get used once every couple of years especlly two stroke engines tund to get gumed up If you can take the carb apart clean it with carb or brake cleaner blow out the passages and clean the neddle valve you don;t to mess with the adjustments and put it back to gether it will work like new
Nov 22, 2010 | Husqvarna Chain Saw 20" Bar
Will not start
remove plug dip in gasoline and try to start there could be something inside the engine restricting fuel may need to look inside motor
May 28, 2010 | Husqvarna Chain Saw 20" Bar
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
47 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
