Question about Jacuzzi Kitchen Iron Black Finish Undermount Sink
When the installers attached my stainless under mount sink to the granite, it shows the edge of the sink instead of the granite overhanging the sink. (the granite hole is bigger than the sink.) I
Granite with undermount sink. When the installers attached my stainless under mount sink to the granite, it shows the edge of the sink instead of the granite overhanging the sink. (the granite hole is bigger than the sink.) I thought the granite was supposed to overhang the sink. Now that it is in, is there anyway to take it out and redo it without damaging the sink and/or the granite, or am I stuck with it this way? He put calk on it but I think that will not be easy to clean when food gets on it.
  • Jacuzzi Master
  • 5,245 Answers
Is it possible they cut the hole wrong?
Call the installer.
Did you pay them?
Take them to small claims court.
Posted on Dec 09, 2012
3 Suggested Answers
  • 18 Answers
SOURCE: will under mounted sink take the weight of garburator?
The sink should be physically mounted with clips if it is not cast iron, otherwise a cradle made of wood is usually the route I go.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Posted on Mar 26, 2011
jyackle5
  • 8197 Answers
No the weight of the disposal will not separate the sink from the granite. When they set the sink they put wood on the edge under the sink to hold the weight of the sink. You will not have a problem.
Posted on Mar 27, 2010
What type of adhesive to use to fasten underhung stainless steel sink to granite countertop
No adhesive will permanently hold the sink, you should have a fabricator drill and install pins to screw the sink into place, you could also push it tight to the stone and then secure it a piece of wood screwed into the back wall of the cabinet.
Oct 23, 2012 | finehomebuilding.com
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
Will under mounted sink take the weight of garburator?
May 15, 2010 | Jacuzzi Kitchen Iron Black Finish...
There were no instructions to install my undermount sink. What can I do?
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
May 15, 2010 | Franke 34" Undermount Double Bowl...
Mar 27, 2010 | Jacuzzi Kitchen Iron Black Finish...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Installing stainless steel sink with metal clips
if you look at edge of sink you will see small rail the bulbous end of clip goes in rail and flat side of clip goes against under side of countertop you then tighten clip which will pull sink and counter together you should install with plumbers putty around rim
Mar 24, 2009 | Neptune Home
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
Installing a drop-in sink
The stone installer told you to use silicone,
what makes you think that you know more than he does about his product.
IF you go use lockdown screws, you will put tension on a thin granite slab at 4 or 6 points around the perimeter of a hole.
stone breaks under very small tensions
do as instructed and silicone the sink in place,
or void any warranty and buy the counter top again when you break it
formica is plastic on a chipboard substrate -not stone
not perhaps the answer you want to hear,
Sep 09, 2008 | Air Tools & Compressors
Jacuzzi Kitchen Iron Black Finish Undermount Sink Logo
180 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
