Question about Philips Televison & Video
Whats the code number for remote control for philips dvd755vr/05
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
Posted on Feb 02, 2008
SOURCE: i need the codes
I have a Magnavox dvd/vcr player and a Phillips universal remote. I was able to get the two to talk to each other by using the code for the brand Funai. This was discovered by entering the model number on google and searching. Magnavox must use their name on the unit but it is in fact a Funai dvd/vcr player.
Posted on Apr 08, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: Need manual for remote control
I need manual for cl015 also...
Posted on Oct 26, 2008
mixelcores
  • 10 Answers
SOURCE: Remote Control Code for Magnavox mdv-430 dvd player
Yes, a Philips replacement remote should be an excellent choice for your Magnavox DVD player, since they are sister companies. I am using the inexpensive Philips URC US2-PH5DSS and it works well. Your Philips remote will come with a page with all manufacturer codes listed by the type of device. Or you can visit the Philips URC code lookup website at www.urc.philips.com.
The codes listed for Magnavox DVD players are:
0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598 You'll have to try them one at a time to see which works best for your player's functions.
Posted on Jan 21, 2009
I need a universal remote code for philips tv 32PFL5522D/05
If the unidentified remote is universal, use code search to find something that will handle some or all functions of your Philips TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jul 26, 2016 | Televison & Video
Tip
ORION TV REMOTE CODE HERE IT IS!!!
Hey I have a Philips Universal remote for an Orion tv. My remote is the following: Model #: PHL PMDVR8K The only way I found my Model was on http://www.circuitcity.com/ccd site. Then I found http://www.fixya.com I called the Philips Accessories # 919-573-7854 and unfortunately there is not a tollfree number. I gave him the only numbers I could find on the remote where the batteries go. CL019, 36/05, and PMDVD6. He had me hold the Code search button down until the light stayed lite. The press the tv button, the light should still be on, then put in 115. Last hit the power button & it worked!! I hope it helps out everyone that needs it.
on Feb 09, 2008 | Philips Magnavox Learning Universal Remote
MODEL REF 22PFL3405H/05
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Nov 27, 2015 | Philips Televison & Video
How do I programme a philips tv 28pw6615/05 without a remote control?
You should have its remote control to program it. No other way.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Dec 28, 2014 | Philips Televison & Video
Need a code for my philips to reprogramme my sky remote my model is 28pt4458/05
Try these codes.
0081
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
Apr 19, 2012 | Philips Televison & Video
Can't find manual for Phillips Universal remote. Need codes for LG TV
what is the your phillips remote model number? Model number is located under the batteries. then go to www.p4c.philips.com to get the codes...hope this helps
Jan 06, 2012 | Philips Magnavox Learning Universal Remote
I need an instruction booklet for dvd755vr/05. Can I download this?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Sep 07, 2011 | Philips Magnavox DVD/VCR Dual Player
Philips universal remote control sru 3030 (roman numerals)IInc/05 wish to obtain the code list
Hello
Get into this link and you can download the manual of Philips universal remote control sru 3030. If you feel any difficulty in downloading the same, send your email address to me by FixYa comment box. I'll send a copy of the manual to you by return mail. OK.
www.p4c.philips.com/cgi-bin/.../cpindex.pl?...SRU3030/
Jun 21, 2011 | Universal Remote Control Hampton Bay...
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
