Question about HP LaserJet M1120 MFP All-In-One Printer
Vertical lines print on the document
The printed document has vertical black lines appear always. They are always similar in all the documents printed,
  • HP Master
  • 1,121 Answers
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Posted on Dec 06, 2012
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
smunteanu
  • 43 Answers
SOURCE: When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Posted on Mar 18, 2008
CWChar
  • 14 Answers
SOURCE: Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Posted on Nov 14, 2008
SOURCE: Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Posted on Nov 15, 2008
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
Multifunction HPLASERJET 3015: when I start copying a document will always print a black vertical line on the right of the page
Advisable for users & tech guys: Lift document feeder unit clean "scan head" glass with glass cleaner, check..
Sep 24, 2011 | HP LaserJet 3015 All-In-One Printer
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Blank vertical line on pages
open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
259 people viewed this question
Seeker5211
Seeker5211
