Question about Husqvarna Garden
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
  • Husqvarna Master
  • 1,807 Answers
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Posted on Feb 09, 2013
  • 97 Answers
SOURCE: no spark
Remove cover & unplug shutoff wir from coil and replace cover & check for spark,if you have spark repair shorted wire or switch.If no spark remove coil and have checked.
Posted on Mar 14, 2009
  • 83 Answers
SOURCE: 46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Posted on Mar 31, 2009
luckyluke78
  • 333 Answers
SOURCE: Husqvarna 40 Chainsaw won't start
The carb uses the pulses from the crankcase to actuate a diaphram in the carb as the fuel pump.If you strip the carb make sure there are no perforations/cracks etc. on these diaphrams and check too that the valve flaps are OK.if not fit a carb kit.
Also check that the pipe or channel from the carb to crankcase is OK.
If all this is correct you can simply put your hand behind the carb or inlet to check for vacuum if not there you have probably blown a crank seal(but unlikely)and you will have to replace them.
Hope this helps,and please come back if you need any further assistance.
Posted on Aug 10, 2009
Testimonial: "Thanks again luckyluke I did find it and was able to clean it through I'm still having the problem of not starting though, carb kit next 90lb cyl comp"
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
Wont start, spews fuel out of combustion chamber, spark plug wet
sounds like the diaphram in the carb ..you will have to take carb apart clean and rebuild or just purchase new carb, I believe there are not to expensive, about 60 bucks..hope this helps..good luck
Sep 06, 2015 | Husqvarna 460 Rancher 24" 60cc Gas Powered...
My Husqvarna model 38096 will not stay running. Cleaned carb, new plug, new gas.
Hi Sonny:
This is the chainsaw section but I think you're playing with a lawnmower, right?
You're saying that it won't stay running. That tells me that it does start, so the spark is OK, and I'd be looking for a fuel delivery problem. Since you cleaned the carb, I'd be looking at a plugged fuel filter or possibly bad fuel.
Jul 09, 2015 | Husqvarna Garden
I have a 2011 husqvarna 345 xtorq only done 2 hours work .i got spark , cleaned out carb new plug still wont start or even fire any ideas plz
did you check for spark? you need air fuel and spark for engine to operate. check all of these then if it still wont start check the ground wire from coil to switch
Aug 14, 2014 | Garden
Husqvarna 36 cc chain saw wont start changed spark plug cleaned carb
Does it have compression.? Does it have a spark.? Is fuel getting into the cylinder.?
Dec 06, 2012 | Husqvarna Garden
Wont start replced spark plug cleaned carb
If you have good fuel and a good spark it may be a mechanical issue, remove the muffler and check the condition of the piston face through the open exhaust port, any signs of damage or scuffing and it will need to come aprt to assess the damage, if all looks good it may be a crank seal leaking, the 36 was prone to blowing the seal behind the flywheel, also check the flywheel key in the flywheel has not sheared knocking the ignition timing out.
Dec 06, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna model 136 chainsaw that wont start.Has spark,gas compression
trie with another spark plug if not heling check maybe air leak between cilinder and carb. also if not helpin rebuild carburattor.
Dec 03, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
372 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
