Question about Zanussi Washing Machines
Error code E43 on john lewis washing machine - Zanussi Washing Machines
  • 240 Answers
SOURCE: e43
unless it says motor control then its the one up front
Posted on Apr 23, 2008
  • 1525 Answers
SOURCE: I have a Frigidaire LTF2140ES1
hello doug just looked a error code e43 board communication problem
shaun
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Error code E43 on display of WPRB9220DCC GE Washer
This is the beginning of a leaking seal in the gear box. Some units have a pan to catch the leak from getting to floor. Seal needs to be replaced, otherwise gearbox will fail (lot more $$$$)
Posted on Mar 16, 2009
barkencoa
  • 3463 Answers
SOURCE: i have had 2 washing machines from john lewis in
If indeed the washers were faulty, personally I would insist on having my money back, and ask for some kind of recompense for the inconvenience you have suffered
Under the sale of goods act, you do not have to accept another washer, as you have 28 days to ask for refund, or indeed another brand of washer.
hope this helps with your problem.
Thankyou.
Posted on Nov 28, 2009
  • 6277 Answers
SOURCE: John Lewis washing machine1203 No matter
Absoultely no promises but it's always worth trying, and indeed doing, this!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 18, 2011
What Does Error Code E90 mean on a John Lewis Washing Machine JLWM1202 made by Electrolux
How should anyone know? Go to the web site and find out so you can be guided accordingly.
Sep 17, 2017 | Electrolux Washing Machines
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
Jul 11, 2015 | Frigidaire 131763202 WASHER DOOR LOCK...
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
Got an error message E43 model WPRB9220D0WW
E43 is for "excessive drive system brake time"
Reset with
1) unplug 3 seconds,
2) hold Power & Start to display "Jr",
3) cycle thru using the Custom 2 button (3 times) to display E43,
4) hold Power & Start to clear code to E00,
5) stop.
Jun 29, 2011 | GE Washing Machines
Flashing E50
This website says it better than I can!
http://www.whitegoodshelp.co.uk/wordpress/zanussi-washing-machine-error-code-e50-also-occurs-on-some-john-lewis-washing-machines/
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 23, 2011 | Zanussi Washing Machines
Please I have got error code H 43 on display monitor of Panasonic washing machine model NA-14VX1, If you please may I know what is meaning this code and where is the problem. Thanks in Advance
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Feb 05, 2011 | Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
