Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Vga componet keeps showing up on the screen.
I HAVE A TFT-LCD MONITOR, AND VGA KEEPS SHOWING UP ON MY SCREEN.
  • kudlae Jan 14, 2009
    I DO NOT HAVE A DELL, I HAVE A GATEWAY FPD2275W MONITOR, THANKS
  • 88 Answers
Assuming safely that you have a Dell E173 monitor, i would suggest the following steps to fix this...
1. Press the (+) button on your monitor to make it do an auto-adjust of the display.
2. On the on screen display (OSD) which can be evoked by using the menu button on your monitor - use the +/- key to get the factory reset option high lighted and press on the menu button to execute it.
This should take care of your problem, let me know how it goes!
Posted on Jan 14, 2009
  • Biju Thomas Jan 14, 2009
    I'm sorry, this question was profiled under - All Products > Dell > E173FPf 17" TFT LCD Flat Panel Monitor > Troubleshooting - wrongly... Hence my mistake, appologize
Screen keeps displaying "adjusting...."
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
Blurred "No Signal" in the TFT when only power cable is connected.
in display settings try to reset the screen resolution
Oct 16, 2008 | Acer AL2216W LCD Monitor
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
Computer monitor
I have never tried that but I would say it won't work that way. I have 2 display cards (3 outputs each, VGA, DVI, TVout) and 3 monitors. When I check the driver software and multiple screen function, it shows only 2 output (VGA and DVI) each. I cannot set TV output as a second screen. Even display properties on windows, it shows only available monitor output. I don't think you can do that.
Thank you,
Tan
Mar 05, 2008 | Dell E153FPc 15" TFT LCD Flat Panel...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
