Question about Generic "Color Copier & Multi-Function Devices - Edition A - Machines Covered: CANON - CLC200, 300, 350, 500, 550, 700, 800, 900, 950, 1000, 1100, 1110, 1120, 1140, 1150, 1160, 1180, 2400, MF8170C, COPYSTAR - CS850D, DANKA - C1600, C1650, C2000, GESTETN [225
ERROR CODE E071-F000 - Generic "Color Copier & Multi-Function Devices - Edition A - Machines Covered: CANON - CLC200, 300, 350, 500, 550, 700, 800, 900, 950, 1000, 1100, 1110, 1120, 1140, 1150, 1160, 1180, 2400, MF8170C, COPYSTAR - CS850D, DANKA - C1600, C1650, C2000, GESTETN [225
I HAVE AN ECOSYS FS- 6525MFP KYOCERA COPIER PRINTER. IT DISPLAYS ERROR CODE F000 WHAT CAN I DO TO RESOLVE THE PROBLEM?
Code
F000
Description
Main PWB - operation panel PWB communication error
Causes
Defective main PWB.
Defective operation panel PWB
PWB = printed write board
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=FS6525MFP&code=F000
Nov 07, 2017 | Kyocera Office Equipment & Supplies
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
SC-810 ERROR E071
hi there
concern ERROR ( E071 ) means Disconnection o motor output connector.
please check the motor output connector for loose connection and disconnection. otherways means IPM module is defective.
if you need more help please contact me.
BEST REGARDS
ASHRAF ABOZID
aabozid@hotmail.com
Dec 24, 2010 | Juki DDL-8700
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
Generic "Color Copier & Multi-Function Devices - Edition A - Machines Covered: CANON - CLC200, 300, 350, 500, 550, 700, 800, 900, 950, 1000, 1100, 1110, 1120, 1140, 1150, 1160, 1180, 2400, MF8170C, COPYSTAR - CS850D, DANKA - C1600, C1650, C2000, GESTETN [225 Logo
29 people viewed this question
Top Generic Office Equipment & Supplies Experts
EE Eddie
Tom Chichester
ray gallant
Are you a Generic Office Equipment and Supply Expert? Answer questions, earn points and help others
