APP78-CF PEGATRON ON BACK IS A LVDS1 AND LVDS2
WHITE SCREEN ON NEW MOTHERBOARD, RECEIVED A WHITE SCREEN, IS LVDS1, OR LVDS2, WHICH CABLE IS FACTOR SET ON BACK OF MOTHERBOARD, WHY A WHITE SCREEN WHEN TURNED ON.
3 Suggested Answers
informatica
  • 1114 Answers
SOURCE: "card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 02, 2007
arniceous
SOURCE: pegatron motherboard diagram where is one?
http://www.findlaptopdriver.com/ipisb-ch2/
Posted on May 12, 2012
Laptop white screen
Having a laptop screen turn white is one of the most frustrating problems a user can experience since it prevents use of the laptop to find a solution.
A white laptop screen indicates a serious problem with the laptop's hardware, and no easy solution to this issue exists.
Just diagnosing this condition requires advanced computer knowledge.
Identification
With this problem, the laptop itself will power on and load the operating system as per usual, but the screen will become a complete, static white, according to LaptopRepair101.
No particular brand or make of laptop falls prey to this issue more than any other; it can happen to any laptop.
Causes
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop.
The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard.
The issue can also reside strictly with the motherboard or the screen might contain a defect.
Considerations Users can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists.
Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
Motherboard Problems
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop.
This requires the user connect the inverter board--the power supply for the LCD backlight and the video cable to the test LCD.
If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Prevention/Solution
Taking apart a laptop screen may make some users feel uncomfortable, so you can use an external monitor connected to the VGA port common to most laptops if the processor and hard drive still work fine. Using an external monitor requires finding the proper function key command to toggle between the LCD and external monitor.
Warning
Taking apart the LCD screen on a monitor likely voids any manufacturer's warranty.
Consider visually checking the video connection to the laptop screen as a last resort if no other viable options exists.
The service manual that came with your laptop likely offers some tips to disassembling the computer, or conditions that could void the warranty.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Jul 02, 2013 | Dell Inspiron Computers & Internet
Slide the phone open and it went to a white screen. turned phone off but when turned back on it was still white screen. I could still feel the vibration when I received a text and I could still make a...
A white screen, especially on slider phones, is usually caused by a loose connection between the video output cable and the phone's motherboard. Unfortunately, opening the phone to access the cable voids the warranty, and is a delicate operation which risks damaging the phone.
Your best solution is to the contact your service provider. Most phones come with a 90 day - 1 year warranty on a service plan.
May 02, 2011 | AT&T Quickfire Cell Phone
How do i connect my home theater system so that i may use the speakers to here my cabel channels
How to connect your cable to your home theater system depends on several factors. So what I'll do is try to cover all of them.
If your home theater RECEIVER has various types of inputs then there will be several ways to do it.
If your cable box has various types of outputs there will also be several ways to do this.
Let's start with the basics.
All cable boxes that I have seen have Red colored and White colored (RCA type) stereo outputs. This also applies to any stereo or Home theater system which will have multiple inputs of the same type and color. If you connect a cable between the cable box's Stereo Outputs and into the cable (or satellite audio inputs of the Home Theater system. Then Switch the Home theater input to the same input, that will work.
If the cable box has an coaxial digital output ORANGE "RCA" TYPE PLUG) and the receiver has the same, connect a single RCA connector between the two. Then go into the input menu of the receiver and change that to digital as opposed to analog. (The red and white ones)
If the two pieces, Receiver and Cable box have optical connectors (little black square door with a red light behind it). Use that and set up the Receiver to receive a digital audio input.
With either the coaxial or optical connections used. You will have full surround sound when it is being broadcast.
Another possibility is that the receiver has discrete RCA input connectors for Left and Right Front, Center, Left and Right Rear and Sub Woofer. Again, if the cable box has these, have at it.
The last one is really simple.
If your equipment is relatively new there will be an HDMI connector on the back of the Receiver. If there is one on the cable box, which often there is for HD cable. Get a single HDMI cable and connect the two together.
I think that is all I know about the subject.
It might be a good idea to print this little article I wrote for you and use it as a reference while looking at the back sides of your home theater receiver and cable box.
I hope I've been a help to you. Please let me know.
Best Regards,
Mark
Jan 21, 2011 | Panasonic Home Theater System System
There is a white screen when i turn my macbook on but nothng more
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop. The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can also reside strictly with the motherboard or the screen might contain a defect.
You can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists. Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
"Motherboard Problems"
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop. This requires the user connect the inverter board--the power supply for the LCD back light--and the video cable to the test LCD. If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Thanks.
Nov 02, 2010 | Apple MacBook Mac Notebook
My HP Pavilion dv2000 laptop screen fades to white, sometimes comes on white, and I wiggle it to get it on. Sometimes restarting the screen helps.
Sounds like you have a loose connection either on the flat video cable on the left side of the motherboard or the inverter cable on the right side of the motherboard that supplies voltage to the screen. Below is a manual for disassembling the laptop down to where you can inspect and reseat the cables.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Nov 12, 2009 | Sony VAIO VGN-CR115E/P Laptop
White screen driving me CRAZY!!!
The issue you are having deals with the "flex cable" connected to the motherboard of your phone to the LCD screen. This cable is very important, because it transfer pixels so that you can view your handset and operate it. Over excessive opening and close the slider, can wear in the flex cable to cause the white/garbled screen. It's not your fault, but the manufacturer and their effort to fail to make a device that can withstand excessive sliding. Check with your local service & repair store. If you do not have insurance, other options will be given you. Thanks. Hope this helps!
Mar 13, 2009 | Samsung SPH-m520 Cell Phone
Hp pavilion dv 6747cl
Looks like a faulty ribbon cable b/n the motherboard and the screen. I would get that checked first..
Oct 26, 2008 | HP Pavilion dv6000z Notebook
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
Foxconn ebot small form factor
press F2 or Del on boot up and see if your drive is listed, if not you may have set the jumper incorrectly on the back of the cdrom drive, if it is shared with the same cable as your hard drive then it should be set as slave, if it's on it's own cable from the motherboard then set it as master. Lastly when in the bios you need to set the cdrom drive as first boot device and when the screen pops up you press enter to boot from cd, so as to install the operating system, if you don't then the pc will look at your hardrive to boot from, finding nothing there.
Aug 22, 2007 | Foxconn EBOT Small Form Factor...
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
