Ghost Image I have two PCs, both HP Vista Home premium... Both have monitors HP w19b. Within 2 weeks of each other they started to have a ghost image to the right of the object. The ghost image is a faint shaded area. The ghost go directly to the right ...not right and down or up, just to the right of it. How do I get rid of it.
  • Anonymous Mar 18, 2009
    Thank you so much, I didn't ask the original question but by simply plugging the monitor in to a different socket, away from the others and changing the position of my speakers my shadow, as explained by the poster above, has been fixed. Thank you. ewan
    Novelist:
  • 121 Answers
Mark165,
Are they both about the same age? Also have you recently added a device that is sitting near the monitors such a an external hard drive, printer, new speakers or power cord or cable next to or against the monitor cable? I sounds like EMI to me, shield the cable or plug of the offending devices into another outlet away from the monitors to test that theory, or having them on a separate surge protector should eliminate the noise you are reporting. Some go as far as adding UPS with line filtering (or conditioning) for the devices - you see it with home theater setups when the TV, computer, games and stereo are all plugged in the same outlets on the same home circuit.
randy320sgi
Posted on Jan 12, 2009
  • Robert Esquire Sep 10, 2013
    There are no electronic devices near the monitor and I reinserted the cord, all to no avail.
Ghost image on a hp CM1415
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
May 08, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
LJ4200 ghosting in middle of page
Perform half test page & check for the ghost image.If half test page not showing ghost image go for 2. (Half test page:while printing open the door, take out the cartridge, remove inside paper gently) 1. check with another cartridge
2. replace teflon sleeve if available or replace fuser assembly..
Nov 29, 2012 | HP LaserJet 4200 Printer
Double image on screen
Usualy in these cases I check the VGA cable. If you can buy new one, but not cheap one will solve the problem. Just to be sure that this is your problem hold the small vga cable cylinders with your hands for 5-6 seconds. When you release them you shouldn't see the ghost image on your screen. It sounds weird but it works. By holding these cylinders you remove the static electricity of the cable. Try to understand what device around your monitor causes the problem. The cause also may be lot of power cables or power sources near the VGA cable.
Dec 18, 2011 | HP 2009M Monitor
Printer prints a faint offset ghost image
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility.
Details and specifications
File name:s.gifHPPDU.exe [1/1, 1.54M]System requirements:s.gifNo additional prerequisitesReleased:s.gif2010-08-13Version:s.gif3.0.0.013Compatibility:s.gifMicrosoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XPFix/Enhancement:s.gifThis version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP LaserJet 5200 Printer
My crt monitor has a white ghost image to the right. It looks like JPEG artifacts. I've replaced the monitor and I've tried another graphics card, but it's still there. The PC is an HP d325.
A ghost on your screen is usually caused by a second or reflection of the same image getting into your monitor, and the space between the real image ant the ghost is the delay in time or extra distance the second image travels before it is displayed on your screen. It is usually caused by a defective video cable or a cable longer than usual like 8 feet or more. Also is your monitor plugged into the same outlet as the computer, and is the case on your computer as all are possible reasons for your problem. Some times adding a ground wire from monitor to computer can correct problem. This can be a problem that takes some real detective work to find, and all I can do is suggest some possible causes.
Oct 09, 2009 | Samtron 76df 17" CRT Monitor
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
Vista on new blank hardrive
Your ACER Extensa should have come with a recovery CD. Just boot up to that CD and follow the instructions.
Apr 15, 2009 | Acer 4220-2346 Notebook
How to format c:drive as it contain vista operating system . i only have a vista recovery disc which only install back vista to its factory level. please suggest me the procedure to format c:drive so...
hi,
yea you may, but make sure that you have already created a *Ghost* image of your current setup.
All you need is a bootable CD with some utilities which will help you out.
Try "hiren's Magic Disk 9.5" : it is bootable disk with proper menus and lots of utilities to make you king of your system.
This disk is usually used by System professionals (including me) :)
Instructions:
1. Boot your system with this magic disk
2. Goto Clone Disk option (Ghost disk)
3. Choose Best compression version
4. utility will start Symantec Ghost which will ask you for the source partition and destination partition for making images.
5. proceed with proper answers.
6. once the ghost imaging is complete, store this ghost image in your external storage drive
7. again boot your system with this magic disk
8. goto Partition utilties
9. Select Acronis Partition manager
10. You'll love to use this software for hard disk maintanence.
Regards,
kuldeep
Nov 14, 2008 | Computers & Internet
Why restore ghost image
You will need to restate your problem in better english.
Jan 07, 2008 | Symantec Client Migration 3.0 Add-On to...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Computers & Internet Logo
783 people viewed this question
David Payne
David Payne
