Question about Refrigerators
We have a RM 7655L Dometic Refrigerator and although it works on both electric supplies it does not work on gas. I can see that the pilot light burning fine so I assume the gas supply is OK especially as the gas hob (which shares the same gas supply) works well. I would appreciate any input to help resolve this problem...
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 532 Answers
SOURCE: RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
Posted on May 10, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
  • 79 Answers
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Posted on Apr 11, 2010
I have a dometic rm 2401 and it won't work on
yes, pretty common issue with that model
May 10, 2012 | Refrigerators
On my dometic refrigerator, modle# rm36e, prod # 9264530, ser # 7090209 the piolt lite will not stay on when I let go of the button
Just like with any older pilot light gas appliance, your refrigerator has a thermocouple which senses heat from the pilot and sends an electrical signal to the pilot valve when it is properly lit. I suspect this thermocouple has gone bad. It will look like a probe sticking into the area of the flame from the pilot and will unscrew from some sort of mounting bracket and have a wire on the other end that plugs into a connector. Generic versions may be available at home appliance repair centers but original replacement would be the best choice. RV repair centers and supply stores will carry it. Do an online search for RV repair supplies or more specific search for Dometic repair centers.
Apr 04, 2012 | Refrigerators
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Oct 12, 2008 | Dometic RM2652 Refrigerator
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
