Question about Remington Shotgun Mount 12Ga Lh, B Square 16801, 870, 1100, 1187 12ga In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts
Removing plug remington 1100 purchased in 1982 - 85 can you tell us how to remove the plug I can't fine a manual which explains the process Someone told my husband you can not remove the plug in the 1100 model. true or false? thank you in advance norma
  • 4 Answers
Remove cap nut that holds for arm on gun. you will see inside the tube a cap with around hole in the center , and a slot also. with a flat screwdriver start prying back and forth carefully out . there is a spring inside that jump out when cap comes out.so be ready when cap comes out. remove spring and plug
Posted on Jan 22, 2013
    Problem Solver:
  • 15 Answers
Remove forecap and barrel. Carefully because magazine spring and follower could pop out. Shake gun back and forth and wood dowel (plug)should slide out
Posted on Feb 09, 2010
How to remove drive sprochet nut
Hello Rndrosse, You need to purchase a tool called a piston stop. You remove the spark plug and replace it with the piston stop. The piston makes contact with the piston stop so you can remove and reinstall the drive sprocket nut.
Oct 31, 2015 | Remington Garden
Remington 742 , 30-06, Ser# A7291753, can someone tell me the year it was made or any other info on it, thanks
Here is a link that explains where they are on the barrel (just ahead of the receiver on the left side of the barrel) and how they work.
http://www.remingtonsociety.com/rsa/questions/ barrelcodes
Contacting Remington Customer Service with the serial number is the best way to verify date of manufacture and will also provide you with information as to exactly what model / version your firearm left the factory as.
Remington Arms Company, LLC
870 Remington Drive
P.O. Box 700
Madison, NC 27025-0700
Oct 25, 2014 | Garden
Remington manufacture date
I would take serial number to nearest gun shop. Ask them to reference the serial. While your there, purchase some ammo, and camo.
Sep 01, 2014 | Remington Shotgun Mount 12Ga Lh, B Square...
How can i tell how old my remington model 1100 is
Hi tommyw57
You will never find a recoil pad made just for the 1100 unless you buy one from a gun show that came off of an 1100.
Go to Walmart and pickup the recoil pad of your choice, install it on your 1100 and draw the outline of the stock on the oversized recoil pad.
Remove the pad from the gun and on a grinder, reduce the size of the recoil pad down to the size that fits the stock of the 1100 that you drew on the oversized recoil pad.
Please take time to rate me
Bud
Oct 31, 2012 | Garden
I have a 96 yamaha 1100 virago I purchased used with no manual. I need to remove seat to access battery. Can someone clue me in how to remove the seat off this bike?
I believe theres 2 small bolts under front of seat...if you pull the cushion back you should see them. Remove the 2 bolts and the front of the seat can lift up....then slide the seat forward as there is a plastic tab that holds the rear of the seat into a slot. The seat should lift off once the tab is clear.
Mar 13, 2011 | Yamaha XV 535 Virago DX Motorcycles
Where air fuel mixture screw located?
Air/fuel adjustment screws are no longer accessible since about 1983. They are adjusted at the factory, and even dealers are subject to a $10,000 fine if they change the adjustment. On the other hand, consumers also take a risk and depending on what state you live in, you may get away with adjusting them yourself. The adjustment screw is usually capped with an aluminum plug and and is very difficult to remove, the carbs may need to be removed to even get at them to try to remove the plugs. Removal involves drilling a hole in the plug, and using a sheet metal screw driven into the drilled hole to pull the plug out. Be advised it is very easy to ruin your carb in the process.
Apr 30, 2010 | 1999 Honda VT 1100 C3 Shadow Aero
I have a feed problem with my Remington 1100 12 gauge. With two shells in the magazine, on ejecting a shell from the firing chamber the feed jams because the second shell in the magazine is not stopped,...
You have a shell stop that is either bent or worn, I think there are 2 in there, would have to look. Go to Gunparts.com for the view and order parts, might find them on ebean. Hope th is helps.
Mar 05, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
Disassemble a remington 11-87 super magnum
Go to the link below to get the manual. In the manual it will tell you how to disassemble the shotgun. It starts on page 14.
http://www.scribd.com/doc/12887293/Remington-1100-1187-Super-Mag-Auto-Shotguns
Good Luck
Nov 01, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Removing Yamaha rear tire (1100 Classic)
do you mean remove the wheel? tires are best left to a shop to do as they have the machine. drive shaft yes? undo all bolts thru frame to final drive casing. slacken wheel nut but do not remove spindle, pull wheel back and out of the frame the drive shaft comes with it, tace out spindle and now lift final drive from wheel, there may be a spacer which might fall out. done deal..
Feb 26, 2009 | 2001 Yamaha V Star 1100 Classic
Remington Shotgun Mount  12Ga Lh, B Square 16801,  870, 1100, 1187 12ga  In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts Logo
582 people viewed this question
Top Remington Cycling Experts
Piyal Perera
Piyal Perera
raysaw
Are you a Remington Cycling Expert? Answer questions, earn points and help others
