Question about Tecnik 23 in. TKH3585 Gas Cooktop
Tecnik TKH 3585 cast iron right side pan support required
Where / from whom, in the United Kingdom can I order a replacement part. The right side cast iron pan support for my Tecnik TKH 3585 4 burner gas hob shattered when accidently dropped. All I have been told by the original sellers of the hob is that I would have to buy a complete new hob at £175!! Someone must sell the parts.
2 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
User Guide worktop make tecnik
I have a full Operating Instruction manual for the Tecnik 23 in. TKH4050 Electric Cooktop.
I would be happy to make a copy for anyone who needs a copy.
Please get in touch.
Feb 12, 2011 | Tecnik 23 in. TKH4050 Electric Cooktop
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Grease-encrusted cast iron trivets
Try soaking in hot soapy water that you've dropped several denture cleaning tablets in. That's helped me get some tough stuff off, or at least loosened up enough that some elbow grease and a scrubbie can finish off the job.
Put them in the oven and run the self clean cycle
Oven cleaner. That stuff is second only to industrial grade hydrogen peroxide
Batender's Friend. That stuff is amazing!
Good Luck
Jul 31, 2010 | Viking 31 in. VGSU101 Gas Cooktop
Ookware should I buy for a Jenn Air
i would avoid cast iron or nickle pans as they are heavy and coarse. i would recomend a nice stainless set with aluminum bottoms
Jul 05, 2009 | Jenn-Air JED8430 Electric Cooktop
Porcelain grate scratched or stained?
If you keep using the range without the aluminum pans it will eventually go away, but aluminum will leave marks on the surface of the grate.
Aug 20, 2017 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
148 people viewed this question
Top Tecnik Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Cooktop Expert? Answer questions, earn points and help others
