Question about LG DLE2514 Electric Dryer
Electric Dryer I have a fairly new LG dryer with a 4-prong plug. I am moving into an older house that has a 4-prong outlet. 1. Is it better to change the dryer cord to a three-prong or the outlet to a 4-prong? 2. If I change to a 3-prong cord on the dryer will it have any adverse effect on the electronic portions of the dryer? (I am asking because of this article: "The four prong standard came about because so many manufacturers were adding things like clocks to their appliances. The standard 220v circuit does not require a neutral, just the two hot legs and a ground. To run 110v accessories built into the appliance, one of the hot legs is tapped, and the fourth leg of the plug, the neutral, is used to make a local 110v circuit. If your new dryer has any electrical accessories (the new Neptune series with all the fancy digital panels come to mind) then your dryer may require a 110v circuit. Without the neutral connected, you would be powering this circuit through the ground, which is a very hazardous situation." Thanks, Dave
No, No, No. The 4th leg is just the ground
Posted on Dec 21, 2007
  • 5,911 Answers
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
Posted on Jul 01, 2007
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I am not sure of the model dryer exactly, but I dont think it matters in this case. The dryer is from a second hand shop, but does not look that old. It is electric, requires a 4 prong 220V outlet. The...
Also on a wing here, but there is a reason for the 4 prong. 2 prongs do control and other 2 supply power to elements. Have seen a simila situation before. Had to use 2 back to back transformers to get drier to function.
Sep 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Burnt smell on dryer
Hello fyffeta,
3 or 4 prong power should have no bearing on the dryer performance..3 prong provides 2 power feed lines and a neutral versus a 4 prong system that provides the same two power feeds, a neutral and a ground.. so performance wise.. you should not expect any. The fact that it sounds louder is subjective and may be a function of the move. whereby something inside the dryer shifted a little when transporting it.. or the accoustics of the new room. If you smell something burning then I would check the exaust duct system for any material and/or restrictions.. It is possible that by moving your dryer..some lint, fibers from clothes or even human hair may have been dislodged and found there way into the blower/heater region and are burning off.. With the plug disconnected..Make sure your power cable terminations at the dryer are all snug. a loose connection there is dangerous and is resistive ( which means it will get hot) and in some cases.. could cause a fire so check that carefully..
In all probability..you may just have some lint or something that shifted during the move and is burning away...
Good Luck
Rick
Jan 03, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
LG DLE2514 Electric Dryer Logo
419 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
