Question about Canon CanoScan 8600F Flatbed Scanner
Canoscan 8600f and windows 8
Can't find a driver for w8/64!! My scanner is worthless!! alernative driver??
SOURCE: Canon Scanner N670U driver for Windows Vista premium for download
I want to Download and install the driver for my scanner.my scanner is CanoScan LiDE 20/N670U/N676U.
Posted on Nov 11, 2008
  • 461 Answers
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Posted on Jan 10, 2009
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
MarcusVR
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Posted on Jan 16, 2010
SOURCE: Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Posted on Mar 14, 2010
I have a CanoScan 8600F. When I want to scan I get the not enough space on the target disk
This seems to happen quite often with the Canon scanners. If you know you have enough space on your hard drive, open the CanoScan Toolbox, then click on Settings and change the folder where the temporary files are stored to another folder of your choice, or create a new one in your documents.
Dec 06, 2010 | Canon CanoScan 8600F Flatbed Scanner
Re: Canon 8600f scanner. How do I get this to file in jpg rather than pdf? How do I control scanned picture size? I get a full page (8.5" x 11.0") with a real size scan on top. Peter
My cannon 8600F was ori=ginally connected to my old laptop & I could scan any document and save as a jpeg file. This was with Windows XP Prof.
Mow my new laptop has Windows 7 & I downloaded Primo from the web. But now I am not able to scan a picture and save as Jpeg file.
Please help.
Aug 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
I have a Canoscan 8600F that hasn't been used for a while. Now that I want to use it but somehow cannot find the software on my computer (accidental deleted?). was able to download the driver but still...
Sorry, but I have been doing this for many, many years and sometimes... the scanner doesn't work anymore when you lose the disk. I did say sometimes. The HP I have is just like that.
May 11, 2010 | Canon CanoScan 8600F Flatbed Scanner
Receive "cannot scan because the original may not be set correct.
Is your Scanner locked ? If yes then you will see there's a solid plastic backing on the inside of the lid that needed to be removed. Also remove all protective plastic too.
Sep 18, 2009 | Canon CanoScan 8600F Flatbed Scanner
Scanner is asking for twain
Hey,
it should come with the drivers
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=13977
click on drivers and downloads, select your windows version and download the drivers and software and install them
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Canon CanoScan 8600F Flatbed Scanner
Lost setup CD
go to the canon website. There you find all the drivers and setup programs that were on the disk for download.
I did the search for you. Go to this link:
CanoScan 8600F support
Select your operating system and you will see download links appear.
Cheers
Critter
Dec 26, 2008 | Canon CanoScan 8600F Flatbed Scanner
CanoScan 8600F
Download the Scanner Driver here for Vista
http://driverscollection.com/?H=CanoScan%208600F&By=Canon
Click Windows Vista and then Download the right choice one for you.
If your don't know if your Vista is either 32-bit or or 64-bit download the second one which will work for either of the 2.
Good luck
Jun 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon CanoScan  8600F Flatbed Scanner Logo
409 people viewed this question
old marine
old marine
