Question about Sewing Machines
My Singer model 780 does not pick up the bobbin threat. How do I correct this/
This is a very old cast iron made machine. Model 780 Cat; 64-10
  • Sewing Machines Master
  • 1,564 Answers
Very old is a relative term. I'm not finding anything under 780 or 6410. So we need to identify your machine. Can you post a picture?
Not picking up bobbin thread is usually one of several things. 1. Wrong needle size, blunted needle, or improperly installed needle. 2. Timing is wrong.
Posted on Dec 07, 2012
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Posted on Mar 06, 2010
I cannnot get my Mother's old Singer Stylinst 416 sewing machince's bobbin to turn. What am I doing wrong?
Your mechanical machine could probably benefit from a professional service. Sounds like it has seized due to old oil that has dried. I've successfully used the following method to resurrect some older seized machines. In addition, the machine may have been knocked out of time when the needle broke. This can be corrected during general service or you can search for "sewing machine timing."
Wheel on right side that controls the needle up and down is very tight...
Singer Stylist 416 Instructions Manual Page 4
Jul 31, 2017 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
How to get the needle pick up the thread from the bobbin
Make sure you have a good needle in and that it is in the correct way round, if that does not work you may need to retime the machine but I need the model number
Jul 22, 2010 | Singer Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
How old is my machine - serial no. V763688 With an attached table and cast iron treadle. ? The Product No. I have put it under is NOT correct - I do NOT know the model no. - only have the above serial no....
Hi, I suspect you wrote the serial number wrong. Here is where to look at the serial numbers and machines years.
http://singerco.com/support/serial_1letter.html
The number you wrote is too high for the machines that start with a V. Check again.
Rick
Aug 02, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
